AnsweredAssumed Answered
HRESULT E_FAIL from ITopologicalOperator.ConstructUnion()
Question asked by yellow_rose on Jul 31, 2015
Latest reply on Oct 7, 2015 by thomasa
I am trying to union polygons but i get this error "Error HRESULT E_FAIL has been returned from a call to a COM component."
at this line :unionedPolygon.ConstructUnion(geometryBag as ESRI.ArcGIS.Geometry.IEnumGeometry);
Here is the code :
public static ESRI.ArcGIS.Geometry.IPolygon MergePolygonsWithCondition(ESRI.ArcGIS.Geodatabase.IFeatureClass featureClass,
String whereClause)
            //Check input objects.
            if (featureClass == null)
                return null;
            try
                ESRI.ArcGIS.Geodatabase.IGeoDataset geoDataset = featureClass as ESRI.ArcGIS.Geodatabase.IGeoDataset;
                ESRI.ArcGIS.Geodatabase.IQueryFilter queryFilter = new ESRI.ArcGIS.Geodatabase.QueryFilterClass();
                queryFilter.WhereClause = whereClause;
                ESRI.ArcGIS.Geometry.IGeometry geometryBag = new ESRI.ArcGIS.Geometry.GeometryBagClass();
                //Define the spatial reference of the bag before adding geometries to it.
                geometryBag.SpatialReference = geoDataset.SpatialReference;
                //Use a nonrecycling cursor so each returned geometry is a separate object.
                ESRI.ArcGIS.Geodatabase.IFeatureCursor featureCursor = featureClass.Search(queryFilter, false);
                ESRI.ArcGIS.Geometry.IGeometryCollection geometryCollection = geometryBag as
ESRI.ArcGIS.Geometry.IGeometryCollection;
                ESRI.ArcGIS.Geodatabase.IFeature currentFeature = featureCursor.NextFeature();
                while (currentFeature != null)
                    //Add a reference to this feature's geometry to the bag.
                    //Since you don't specify the before or after geometry (missing),
                    //the currentFeature.Shape IGeometry is added to the end of the geometryCollection.
                    object missing = Type.Missing;
                    geometryCollection.AddGeometry(currentFeature.Shape, ref missing, ref
            missing);
                // Create the polygon that will be the union of the features returned from the search cursor.
                // The spatial reference of this feature does not need to be set ahead of time. The
                // ConstructUnion method defines the constructed polygon's spatial reference to be the
                // same as the input geometry bag.
                ESRI.ArcGIS.Geometry.ITopologicalOperator unionedPolygon = new ESRI.ArcGIS.Geometry.PolygonClass();
                return unionedPolygon as ESRI.ArcGIS.Geometry.IPolygon;
            catch (Exception ex)
                Logger.LoggerInstance.LogError(ex.Message, DateTime.Now, "MergePolygonsWithCondition",
"SpatialOperations", "");
                throw new Exception(ex.Message);
Outcomes
