How do I list addresses from a locator service only if the address entered is not in the locator service?
2037
07-30-2015 09:30 AM
ChrisSergent
Regular Contributor III
I have an input box that the user enters an address into. I want to then check the locator service and see if the address is in there. If the address is in the locator service, I don't want to do anything, but if the address is not in the locator service, I want the locator service to provide the alternatives as a list. The score for the locator service is already set.
My updated code is here: JS Bin - Collaborative JavaScript Debugging
Right now the code just returns the address that is in the input box. There should be two alternatives.
Any idea why these aren't showing Rene Rubalcava​? I copied the code from the sample we worked on.
ReneRubalcava
It's not returning any results. The issue is JSBIN running in a mixed HTTP/HTTPS environment. Your server isn't set up for HTTPS, so you need to change all URLs to HTTP, including the JSBIN link like this
ReneRubalcava
ChrisSergent
That is a pain going back and forth for sharing code, but I will keep it in mind. Thanks.
