how to publish a WMTS Server with ArcEngine
2789
07-22-2015 01:37 AM
qiangyan
I Can publish a Sever blow: but "Single Fused Map Cache" is false.  it's not a wmts Server.
         IServerObjectAdmin pServerObjectAdmin;
            pServerObjectAdmin = ConnectAGS("http://localhost:6080/arcgis/admin", "arcgis", "79");
            IServerObjectConfiguration2 configuration = (IServerObjectConfiguration2)pServerObjectAdmin.CreateConfiguration();
            IEnumServerObjectConfiguration ss = pServerObjectAdmin.GetConfigurations();
            IServerObjectConfiguration2 pp;
            for (int i = 0; i < ss.Count; i++)
                pp = (IServerObjectConfiguration2)ss.Next();
                String name = pp.Name;
                if (name == servername)
                    return;
            configuration.Name = servername;
            configuration.TypeName = "MapServer";
            IPropertySet props = configuration.Properties;
            props.SetProperty("FilePath", filepath);
            object names, values;
            props.GetAllProperties(out names, out values);
            props.SetProperty("OutputDir", @"F:\arcgisserver\directories\arcgisoutput");
            string VirtualOutPutDir = "/rest/directories/arcgiscache";
            props.SetProperty("VirtualOutPutDir", VirtualOutPutDir);
            props.SetProperty("SupportedImageReturnTypes", "URL");
            props.SetProperty("MaxImageHeight", "2048");
            props.SetProperty("MaxRecordCount", "500");
            props.SetProperty("MaxBufferCount", "100");
            props.SetProperty("MaxImageWidth", "2048");
            props.SetProperty("outputDir", @"F:\\arcgisserver\\directories\\arcgisoutput");
            props.SetProperty("isCached", "true");//
            props.SetProperty("minScale", "500000"); //
            props.SetProperty("tilingScheme", "3");//
            props.SetProperty("maxScale", "32000");//
            //props.SetProperty("CacheOnDemand", "true");//
            props.SetProperty("IgnoreCache", "false");//
            props.SetProperty("antialiasingMode", "None");//
            props.SetProperty("ClientCachi@ngAllowed", "true");
            props.SetProperty("CacheDir", "F:\\arcgisserver\\directories\\arcgiscache");
configuration.set_ExtensionEnabled("WMServer", true);
IPropertySet wmsprops = configuration.get_ExtensionProperties("WMServer");
How do I set up properties?
Thank you for your helper.
Tags (1)
