Desire Lines to Polygons
3030
6
07-20-2015 12:14 PM
JoannaMiron
Hi There,
I'm sure this is possible, my brain just might not be working. I have received line work from a consultant that are basically like desire lines.  Is there a way of making these into  polygons?  I'm looking to create these polygons based on an attribute from the line work.
Any help would be great
Thanks!
Joanna
IanMurray
WesMiller
Regular Contributor III
There is a feature to polygon tool the lines must intersect to create polygons
IanMurray
If you have an advanced license, you can use the feature to polygon data management tool.
JoannaMiron
The lines don't actually intersect.  They radiate out from a location like a spider diagram.  I was wondering if there was a way to connect these radiating lines together based on an attribute.
I might be asking too much.
IanMurray
Maybe try Minimum Bounding Geometry - Convex Hull?
http://resources.arcgis.com/en/help/main/10.1/index.html#//00170000003q000000
JoannaMiron
I'll give this a try.
Thanks!
JoannaMiron
This seems to have done a pretty good job.
Thank you!
