JS api geometryEngine distance units
3710
07-13-2015 05:14 PM
LukePhilips
New Contributor III
I'm trying out the geometryEngine api from the JavaScript framework and it doesn't seem to work as intended.
Some code to do distance between two points:
require(["esri/geometry/geometryEngine"], function(geometryEngine) {
          this.sr = new esri.SpatialReference({
            wkid: 4326 //decimal degrees
this.distanceUnit = 9001;
var distance = new Number(0);
geometry1 = new esri.geometry.Point(-105, 40, this.sr);
        geometry2 = new esri.geometry.Point(-100, 30, this.sr);
        distance = geometryEngine.distance(geometry1, geometry2, this.distanceUnit);
the distance returned seems to be a decimal-degree unit, not ever the units I specify (e.g. 9001:meter, 9036:kilometer, 9035:mile)
Is there something I'm missing?
