Web AppBuilder- Legend
3347
07-10-2015 10:56 AM
RickeyFight
MVP Regular Contributor
I have 3 layers turned on in WAB. The Legend does not show two of the layers in it.
The same layers are turned on in Arcgis Online.
I cannot share my app and I have no errors in the console.
Does anyone know why this could happen? And how to fix it?
LemaoWu
Rickey,
The possible reason might be:
The Auto Update and Respect Current Map Scale are checked in Legend widget, and in this case, the CoA Water layer (and its sub-layers) is not visible in current map view/scale or it's turned off in layer list.
RobertScheitlin__GISP
Rickey,
   As long as you have the "show in legend" option check for those layer in the webmap, then they should be showing and this is a bug and should be reported to esri tech support.
RickeyFight
Robert,
They are checked. I will talk to tech support.
Thank you
(I am going to leave this open until I talk to esri)
LemaoWu
Rickey,
RickeyFight
Lemao,
I cannot believe i did not realize that!
Thank you!
