polyline not visibel
3023
07-09-2015 05:49 PM
LefterisKoumis
Occasional Contributor III
       I have this simple code but the polyline is not drawing. The answer, I suspect is simple...but not for a novice in js. Thanks.
<!DOCTYPE html>
<html>
  <head>
    <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
    <title></title>
    <link rel="stylesheet" href="https://community.esri.com//js.arcgis.com/3.7/js/esri/css/esri.css">
    <style>
      html, body, #map {
        height: 100%; width: 100%; margin: 0; padding: 0;
    </style>
    <script src="//js.arcgis.com/3.7/"></script>
    <script>
      var map;
      require([
        "esri/map",
        "esri/geometry/Point",
        "esri/symbols/SimpleMarkerSymbol",
  "esri/symbols/SimpleLineSymbol",
        "esri/graphic",
  "esri/geometry/Polyline",
  "esri/SpatialReference",
        "esri/layers/GraphicsLayer",
        "dojo/domReady!"
      ], function(
        Map, Point, SimpleMarkerSymbol, SimpleLineSymbol, Graphic, Polyline, SpatialReference, GraphicsLayer
        map = new Map("map", {
          basemap: "streets",
          center: [-122.16,37.7238],
          zoom: 10
        map.on("load", function() {
          var gl = new GraphicsLayer();
  var myspatialref = new SpatialReference({wkid:102100});
          var p = new Point((-122.159, 37.724),new SpatialReference(102100));
  var t = new Point((-122.169, 37.721),new SpatialReference(102100));
  var coords=[];
  coords.push([p,t]);
  var polyline = new Polyline(myspatialref);
  var polylineSymbol = new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, 0xFF3333,1,3);
  polyline.addPath(coords);
  var polylineGraphic = new Graphic(polyline, polylineSymbol);
          gl.add(polylineGraphic);
          map.addLayer(gl);
    </script>
  </head>
  <body>
    <div id="map"></div>
  </body>
</html>
ChrisSmith7
Here's a working sample, slightly modified from yours:
<!DOCTYPE HTML>
<html>
<head>
  <meta charset="utf-8">
  <title>My Map</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.13/esri/css/esri.css">
  <style>
    html, body, #map {
      padding:0;
      margin:0;
      height:100%;
  </style>
  <script src="//js.arcgis.com/3.13/"></script>
  <script>
      require([
        "dojo/ready",
        "dojo/parser",
        "esri/map",
        "esri/graphic",
      ], function(
        ready,
        parser,
        Map,
        Point,
        SimpleMarkerSymbol,
        SimpleLineSymbol,
        Graphic,
        Polyline,
        SpatialReference
        ready(function() {
          parser.parse();
          myMap = new Map("map", {
            basemap: "streets",
            zoom: 15,
            SpatialReference: 4326
          myMap.on("load", function() {
            var point1 = new Point(-122.159, 37.724, myMap.SpatialReference);
            var point2 = new Point(-122.169, 37.721, myMap.SpatialReference);
            var line = new Polyline(myMap.SpatialReference);
            line.addPath([point1, point2]);
            var lineSymbol = new SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0,0.5]),4);
            var pointSymbol = new SimpleMarkerSymbol().setColor(new dojo.Color([255,0,0, 0.5]));
            myMap.graphics.add(new Graphic(point1, pointSymbol));
            myMap.graphics.add(new Graphic(point2, pointSymbol));
            myMap.graphics.add(new Graphic(line, lineSymbol));
  </script>
</head>
<body>
  <div id="map" class="map">
  </div>
</body>
</html>
JoelBennett
MVP Regular Contributor
Set the wkid of your spatial reference to 4326 instead of 102100.  Your coordinates are in WGS 84, not Web Mercator.
ChrisSmith7
<!DOCTYPE HTML>
<html>
<head>
  <style>
    html, body, #map {
      padding:0;
      margin:0;
      height:100%;
  </style>
  <script>
      require([
        "dojo/ready",
        "dojo/parser",
        "esri/map",
        "esri/graphic",
      ], function(
        ready,
        parser,
        Map,
        Point,
        SimpleMarkerSymbol,
        SimpleLineSymbol,
        Graphic,
        Polyline,
        SpatialReference
        ready(function() {
          parser.parse();
            basemap: "streets",
            zoom: 15,
  </script>
</head>
<body>
  </div>
</body>
</html>
LefterisKoumis
Thanks. I modified it so I can use the GraphicsLayer.
