Not able to zoom to location in ios application when using arcgis online map
3073
07-08-2015 08:52 AM
sujeetyadav
New Contributor III
I am performing search operation in my ios application on an arcgis online bundle map it consist of three service layer topmost layer is feature service layer then a map service layer and then basemap. I call this bundle in my IOS application for viewing and editing my map features. Now i have a polygon layer in my map service layer when i perform search operation in my application on polygon layer then the search result shows the pop up result on some other extent.
But when i call map service directly from rest url in my application then the result shows correct popup
GagandeepSingh
Occasional Contributor II
Is it possible for you to share some screenshots, for better understanding?
sujeetyadav
New Contributor III
I am calling the mapview on id basis and the map id link is http://www.arcgis.com/home/item.html?id=8ed749396e9945a89c71e5cc05c61dad
Whenever i search a single parcel polygon every time it locate me to different location
GagandeepSingh
I am still not clear on what you are trying to do. What do you mean by a `search operation`? Can you share some code showing when it works and when it does not. Or again, some screenshots for both success and failure.
