AnsweredAssumed Answered
Select points and update attributes base on parcels
Question asked by CCweedcontrol on Jul 8, 2015
Latest reply on Jul 9, 2015 by rfairhur24
I am working a code/button that will help me update address points attributes based on the parcel they are in.
I am trying to to use filed list to create a mach and update the points with dictionaries. I don't not get error but my address points don't get updated from the parcels. I would appreciate any help with my code.
import arcpy
from datetime import datetime as d
startTime = d.now()
#set to folder where features are located
arcpy.env.workspace = r"Database Servers\DSD15_SQLEXPRESS.gds\TEST (VERSION:dbo.DEFAULT)" #r"Database Servers\DSD15_SQLEXPRESS.gds\TonyTwoWay (VERSION:dbo.DEFAULT)" #on windows use \ instead of /
arcpy.env.qualifiedFieldNames = False
#define variables for cursor
FC = "TEST.DBO.CCAPTEST"  #pointlayer
TaxPar = "TaxParcels" #Parcels
poly = "ACCOUNT"#'SiteAddres_1','SiteAddres_1', 'SiteNum_1', 'SiteNumSfx_1','Predir_1','SiteStreet_1', 'StreetType_1', 'Postdir_1', 'SiteCity_1', 'SiteZIP_1', 'OwnerName_1'
Pnt =  "Account"#
TaxPar1 = "selectedParcels"
parcelsCount = int(arcpy.GetCount_management(FC).getOutput(0))
dsc = arcpy.Describe(FC)
selection_set = dsc.FIDSet
if len(selection_set) == 0:
    print "There are no features selected"
elif parcelsCount >= 1:
    #Select parcel within selected Address Points
    arcpy.SelectLayerByLocation_management(TaxPar, "CONTAINS", FC)
    #Create in memory parcel layer
    selectedParcels = arcpy.MakeFeatureLayer_management(TaxPar, TaxPar1)
    arcpy.SelectLayerByAttribute_management(TaxPar1, "NEW_SELECTION", "OBJECTID= "+OID)
    # define the field list from the parcels
    sourceFieldsList = ["ACCOUNT", poly,"SiteAddres",'SiteNum', 'SiteStreet','SiteNumSfx','Predir','SiteStreet', 'StreetType', 'Postdir', 'SiteCity', 'SiteZIP', 'OwnerName']
    # define the field list to the points
    updateFieldsList = ["Account", Pnt,"SiteAddres", 'SiteNum', 'SiteStreet', 'SiteNumSfx','Predir','SiteStreet', 'StreetType', 'Postdir', 'SiteCity', 'SiteZip', 'OwnerName']
    # Start an edit session. Must provide the workspace.
    edit = arcpy.da.Editor(arcpy.env.workspace)
    # Edit session is started without an undo/redo stack for versioned data
    #  (for second argument, use False for unversioned data)
    edit.startEditing(True)
    # Start an edit operation
    edit.startOperation()
    # populate the dictionary from the polygon
    valueDict = {r[0]:(r[1:]) for r in arcpy.da.SearchCursor(TaxPar1, sourceFieldsList)}
    with arcpy.da.UpdateCursor(FC, updateFieldsList) as updateRows:
        for updateRow in updateRows:
            keyValue = updateRow[0]
            if keyValue in valueDict:
                for n in range (1,len(sourceFieldsList)):
                    updateRow[n] = valueDict[keyValue][n-1]
                updateRows.updateRow(updateRow)
    # Stop the edit operation.
    edit.stopOperation()
    # Stop the edit session and save the changes
    edit.stopEditing(True)
arcpy.RefreshActiveView()
#arcpy.Delete_management(sjpoints)
Outcomes
