Problems with mosaic dataset
19217
12
06-30-2015 02:00 PM
MihaKlemencic
New Contributor III
I am working with mosaic dataset and I found a problem. If I run tool Add rasters to mosaic dataset with enabled Update overviews I get this messages:
  • Error: 8004206f: Could not initialize the mosaic dataset's parallel processing engine.
  • Error: 80040213: Configuration RasterCommander.ImageServer can not be started.
  • Server Object instance creation failed on machine MIHA.
  • Image Server is not supported with the current license.
The last one is strange because I work with ArcGIS Desktop not Server.
But the last thing is very strange. If I wait some seconds after the problem is reported and then close dialog box, the overviews are created for entire mosaic dataset.
I have installed ArcGIS 10.3.1 with 64-bit geoprocessing.
Can somebody explain this issue?
Message was edited by: Miha Klemencic
Tags (1)
JayantaPoddar
MVP Esteemed Contributor
Hi Miha,
Try this:
Go to Environment Settings (in tool's dialog box) > Parallel Processing. Define the parallel processing factor as 0 (zero). Run the tool. Any error?
Think Location
JayantaPoddar
Hi Miha,
Try this:
Think Location
MihaKlemencic
New Contributor III
Problem solved
Thank you, Jayanta!
JuanPeralta1
New Contributor III
I have the same problem, although in my case I get it creating a cache ("Manage Tile Cache" tool, ArcGIS Desktop 10.3), but setting Parallel Processing=0 does not solve it. Anything else to try?
AlessandroValra
Occasional Contributor III
Using "Manage Tile Cache" tool in ArcMap 10.4.1 this has fixed the problem for me as well.
Mandalorian
New Contributor III
4 years later and this suggestion resolved the problem for me as well! Thanks, Jayanta Poddar‌!
ingeoivanherrera
Hi JayantaPoddar1, I got the same message when using the fill tool, but your recommendation solved the problem. Thank you!!
JuanDavidMercadoLeal
Thank you so much!
BabithaGanesh
Thank you so much
Wandabwa_Isaiah
This solution worked perfectly to solve the same error I was experiencing in Arcmap version 10.8. Thank you so much!
