AnsweredAssumed Answered
CityEngine Text Attribute Rule
Question asked by Lukaszczar on Jun 29, 2015
Latest reply on Jul 2, 2015 by Lukaszczar
I would like to use a Rule to create a text from attributes that would be embedded into a room polygon, and base on its length (horizontal or vertical) (See the attachment) also wit would be good to scale text base on the polygon size
This example I use one Rule per Room - that's why its different orientation/ size
And here is the Rule I have been using,
Can you help me modify this Rule, so I can use only one Rule for all my floors ( and get all the room names - scaled and placed horizontal/vertical- based on it room area?)
Thank you!
Lukasz
* File:    3D_Text.cga
* Created: 13 May 2014
* Changed: 19 Aug 2014
* Author:  chri7180
version "2014.0"
# Important Note: Procedural Runtime setting for Max Derivation Depth
# must be raised above default for rule to print longer text.
# Go to Edit > Preferences > General > Procedural Runtime.
# Set Max Derivation Depth to 1000 (an arbitrarily large value).
# USEFUL FOR TESTING:
#    the quick brown fox jumps over the lazy dog
#    THE QUICK BROWN FOX JUMPS OVER THE LAZY DOG
#    ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789,.'[]{}~!@#$%^&()-_=+*:><|?/\
#    Special Char Test: ;,.'[]{}~!@#$%^&()-_=+*:><|?/\
# To make more fonts, email cwilkins@esri.com for instructions.
# Change below directories for your use.
const assetsDirectory = "assets/3D_Text/" + Font + "/"
const assetsDirectoryLower = assetsDirectory + "Lower/"
@Group("DISPLAY", 10) @Order(10)
@Order(1)
attr Text = "Floating;3D TEXT;is Cool"
#attr Text = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789,.'[]{}~!@#$%^&()-_=+*:><|?/"
@Group("DISPLAY") @Order(20)
@Color
attr Color = "#00FF00"
@Group("DISPLAY") @Order(30)
attr White_Underlay = false
@Group("DISPLAY") @Order(40)
@Range(0,1)
attr Transparency = 0
@Group("DISPLAY") @Order(50)
@Range("Arial")
attr Font = "Arial"
@Group("POSITION & SIZE", 20) @Order(10)
@Range(0,200)
attr Elevation = 0.2
@Group("POSITION & SIZE") @Order(20)
@Range(1,5)
attr Font_Height = 1
@Group("POSITION & SIZE") @Order(30)
@Range(0,100)
attr Font_Depth = 0.2
@Group("POSITION & SIZE") @Order(40)
@Range(-180,180)
attr Rotation_Y = 90
@Group("POSITION & SIZE") @Order(50)
@Range(-90,90)
attr Tilt = 90
@Group("RELATIVE SIZE", 30) @Order(60)
@Range(0,1)
attr Kerning = 0.15
@Group("RELATIVE SIZE") @Order(70)
@Range(0,1)
attr Stretch_Horizontal = 0
@Group("RELATIVE SIZE") @Order(80)
@Range(0,1)
attr Line_Spacing = 0.5
@Group("RELATIVE SIZE") @Order(90)
@Range(0,1)
attr Space_Size = 0.3
@StartRule
Generate -->
    color(Color)
    set(material.opacity, 1 - Transparency)
    alignScopeToAxes(y)
    # XX Is Tilt tilting around the right Z axis?
    r(-Tilt, Rotation_Y, 0)
    translate(rel, world, 3, Elevation, -1)
    PrintLines(Text, 1)
@Hidden
attr Line = ""
@Hidden
attr ReturnAt = 0
const Max_Lines = 20
# FIXME: multiple semi-colons in a row just make spaces. Not sure why. Not important for now.
PrintLines(myString, lineIndex) -->
    case len(myString) <= 0 || lineIndex > Max_Lines:
        NIL
    else:
        case find(myString, ";", 2) > 0:
            set(ReturnAt, find(myString, ";", 0))
            PrintLetters(substring(myString, 0, ReturnAt))
            t(0, -(Font_Height * (1 + Line_Spacing)), 0)
            r(0,0,0)
            t(0,0,0)
            PrintLines(substring(myString, ReturnAt + 1, Max_String_Length), lineIndex + 1)
        else:
            PrintLetters(substring(myString, 0, Max_String_Length))
            NIL
# Used during recursion on Text:
@Hidden
attr Letter = ""
@Hidden
attr Asset = ""
const Max_String_Length = 1000
PrintLetters(myString) -->
    PrintLetters(myString, len(myString))
PrintLetters(myString, n) -->
    case n > 0:
        set(Letter, substring(myString, 0, 1))
        set(Asset, getLetterAsset(Letter))
        PrintLettersHandleCursorMoves(myString, n)
    else:
        NIL
PrintLettersHandleCursorMoves(myString, n) -->
    case Letter == " ":
        # Printing a space only moves the cursor. No asset used.
        PrintLettersRecurse(myString, n)
    else:
        PrintLettersAssetSetup(myString, n)
PrintLettersAssetSetup(myString, n) -->
    case !fileExists(Asset):
        print("Error: No file for asset='"+Asset+"'")
    else:
        # This one letter is printed in a separate branch.
        PrintLetter
PrintLettersRecurse(myString, n) -->
    t((_assetSizeX  + Kerning + Stretch_Horizontal) * Font_Height, 0, 0)
    PrintLetters(substring(myString, 1, Max_String_Length), n - 1)
_assetSizeX =
    case Letter == " ":
        Space_Size
    else:
        sx(Asset)
PrintLetter -->
    s(0,0,0)
    insert(Asset, Font_Height)
insert(a, scalar) -->
    i(a)
    s(scalar * sx(a), scalar * sy(a), scalar * sz(a))
    t((scalar * tx(a)) - tx(a),(scalar * ty(a)) - ty(a),(scalar * tz(a)) - tz(a))
    s('(1 + Stretch_Horizontal),'1,0)
    WhiteUnderlay
sx(asset) = assetInfo(asset, sx)
sy(asset) = assetInfo(asset, sy)
sz(asset) = assetInfo(asset, sz)
tx(asset) = assetInfo(asset, tx)
ty(asset) = assetInfo(asset, ty)
tz(asset) = assetInfo(asset, tz)
WhiteUnderlay -->
    case White_Underlay:
        # Weird push/pop notation that I've never seen anyone use:
            color(1,1,1)
            extrude(underlayDepth)
            X.
        t(0, 0, underlayDepth)
        extrude(overlayDepth)
        X.
    else:
        extrude(Font_Depth_Non_Zero)
const flatUnderlayPercent = 0.05
const underlayDepth = Font_Depth_Non_Zero * (1 - flatUnderlayPercent)
const overlayDepth = Font_Depth_Non_Zero * (flatUnderlayPercent)
const Font_Depth_Non_Zero =
    case Font_Depth <= 0:
        Font_Height * 0.05
    else: Font_Depth
# Letter Assets - this finds the OBJ file for each letter.
getLetterAsset(letter) =
    # These characters cannot be used for filenames:  *!:><|?/\
    # Below case structure relates those characters to specially named assets.
    # The else case is for all other characters.
    case letter == " " : ""
    case letter == "*" : getAssetPath(letter) + "_asterisk.obj"
    case letter == "!" : getAssetPath(letter) + "_bang.obj"
    case letter == ":" : getAssetPath(letter) + "_colon.obj"
    case letter == ">" : getAssetPath(letter) + "_greaterthan.obj"
    case letter == "<" : getAssetPath(letter) + "_lessthan.obj"
    case letter == "|" : getAssetPath(letter) + "_pipe.obj"
    case letter == "?" : getAssetPath(letter) + "_question.obj"
    case letter == "/" : getAssetPath(letter) + "_slash.obj"
    case letter == "\\" : getAssetPath(letter) + "_backslash.obj"
    case letter == "\"" : getAssetPath(letter) + "_quote.obj"
    else: getAssetPath(letter) + letter + ".obj"
getAssetPath(letter) =
    case isLowercase(letter): assetsDirectoryLower
    else: assetsDirectory
isLowercase(letter) =
    case letter == "a" : true
    case letter == "b" : true
    case letter == "c" : true
    case letter == "d" : true
    case letter == "e" : true
    case letter == "f" : true
    case letter == "g" : true
    case letter == "h" : true
    case letter == "i" : true
    case letter == "j" : true
    case letter == "k" : true
    case letter == "l" : true
    case letter == "m" : true
    case letter == "n" : true
    case letter == "o" : true
    case letter == "p" : true
    case letter == "q" : true
    case letter == "r" : true
    case letter == "s" : true
    case letter == "t" : true
    case letter == "u" : true
    case letter == "v" : true
    case letter == "w" : true
    case letter == "x" : true
    case letter == "y" : true
    case letter == "z" : true
    else: false
Outcomes
