WebApp Builder - Adding layers
5391
6
06-28-2015 04:07 PM
HamishKingsbury1
Hi All
I'm working on developing a widget for Web App builder and what i'm trying to do is add a layer that has been created by the user in the web browser. In he JS API you can do something along the lines of:
map.addLayer();
However this is not working with the WebApp Builder. Below is the code I currently have with hard coded points:
var facilitiesGraphicsLayer = new GraphicsLayer();
facilitiesGraphicsLayer.setRenderer(Renderer);
facilitiesGraphicsLayer.add(new Graphic(new Point(1460355.1631064715,5082544.779264613,_viewerMap.__tileInfo.spatialReference))); /facilitiesGraphicsLayer.add(new Graphic(new Point(1564363.8936586068,5184488.835737464,_viewerMap.__tileInfo.spatialReference)));
facilitiesGraphicsLayer.add(new Graphic(new Point(1577894.9077129958,5222140.389124587,_viewerMap.__tileInfo.spatialReference)));
facilitiesGraphicsLayer.add(new Graphic(new Point(1655876.6269847318,5306365.449387112,_viewerMap.__tileInfo.spatialReference)));
facilities = new FeatureSet();
facilities.features = facilitiesGraphicsLayer.graphics;
What I am after is (with a button press) the points in the facilities feature set to be added to the map.
Any help is appreciated
Cheers
Hamish
RobertScheitlin__GISP
Hamish,
  When building widgets you have easy access to the map by using "this.map"
So it would look something like this:
this.map.addLayer(yourLayer);
Hamish,
HamishKingsbury1
Brilliant, thank you. I am however running into another issue. Using the RouteTask Api (making a custom widget that requires inputs that can't be done by the directions widget) I can't display the returned route. Below is some of my code. The comment section is another of my attemps. Both of them dispaly the error 'TypeError: this.Map.graphics is undefined'
// routeTask.on("solve-complete", function(evt){
        //     routeSymbol = new SimpleLineSymbol().setColor(new Color([0, 0, 255, 0.5])).setWidth(5);
        //     document.getElementById("routeResult").innerHTML = "Total Distance (optimized) is "+(((Math.round(evt.result.routeResults[0].directions.totalLength*100))/100).toFixed(2))+"kms.";
        //     toggle_visibility('calcloading','hide');
        //     route = evt.result.routeResults[0].route.setSymbol(routeSymbol);
        //     this.map.graphics.add(route);
        routeTask.on("solve-complete", this.this);
        routeTask.on("error",function(){
            alert('nay');
    this: function(evt){
var facilitiesGraphicsLayer = new GraphicsLayer(); facilitiesGraphicsLayer.setRenderer(Renderer); facilitiesGraphicsLayer.add(new Graphic(new Point(1460355.1631064715,5082544.779264613,_viewerMap.__tileInfo.spatialReference))); /facilitiesGraphicsLayer.add(new Graphic(new Point(1564363.8936586068,5184488.835737464,_viewerMap.__tileInfo.spatialReference))); facilitiesGraphicsLayer.add(new Graphic(new Point(1577894.9077129958,5222140.389124587,_viewerMap.__tileInfo.spatialReference)));  facilitiesGraphicsLayer.add(new Graphic(new Point(1655876.6269847318,5306365.449387112,_viewerMap.__tileInfo.spatialReference)));  facilities = new FeatureSet(); facilities.features = facilitiesGraphicsLayer.graphics;
Hamish,
   From the looks of your code the context of "this" inside your function is not what it needs to be. It looks like you are defining this as a function and therefore "this" does not have a map property. You can use dojos lang.hitch to maintain context of "this" in your functions. If you look t any of the esri otb widget you will see many good examples of best practice coding you can follow.
HamishKingsbury1
Thanks for that, I've read through the documentation on the Dojo website however it is making little sense to me. I have also looked at some of the included widgets (Geocoder and LayerList) for how they use lang.hitch but again, that is not being overly helpful.
Are you able to give a clear(ish) example?
Cheers
Hamish,
   See if this thread helps any. If not I can try to go into more detail.
lang.hitch what does it do?
HamishKingsbury1
Yay! thank you so much!
