Folks
Is this expected to work?
I cannot get it to go.
I am guessing I have to create a new RelationQuery through code.
Let me know.
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Query State Info without Map</title> <script src="http://js.arcgis.com/3.13/"></script> <script> require([ "dojo/dom", "dojo/on", "esri/tasks/query", "esri/tasks/QueryTask", "dojo/domReady!" ], function (dom, on, Query, QueryTask ) { var queryTask = new QueryTask("http://localhost:6080/arcgis/rest/services/Ggov/MI_Default/MapServer/7/queryRelatedRecords"); var query = new Query(); query.returnGeometry = false; query.outFields = ["*"]; query.relationshipId = 0; query.objectIds = [2, 3]; queryTask.execute(query, showResults); function showResults(results) { var resultItems = []; var resultCount = results.features.length; for (var i = 0; i < resultCount; i++) { var featureAttributes = results.features.attributes; for (var attr in featureAttributes) { resultItems.push("<b>" + attr + ":</b> " + featureAttributes[attr] + "<br>"); } resultItems.push("<br>"); } dom.byId("info").innerHTML = resultItems.join(""); } }); </script> </head> <body> <div id="info" style="padding:5px; margin:5px; background-color:#eee;"> </div> </body> </html>
Keith Anderson
Solved! Go to Solution.
Keith,
You need to use the RelationshipQuery class and the QueryTasks executeRelationshipQuery method.
Keith,
Thanks Robert...Thats what I am working on now..
I take that back... I am using .queryRelatedFeatures.
I will check into .executeRelationshipQuery too.
Thanks Robert
