JS API 3.13 - IdentifyParameters undefined?
4141
6
06-11-2015 02:19 PM
LauraMiles1
Occasional Contributor III
Hi All,
I've been struggling with this code, everything has been working until I tried to throw in the ability to identify. When I run the code, I get the error that identifyParams is undefined. Specifically, "Uncaught TypeError: Cannot set property 'geometry' of undefined"
Can anyone see what I've got wrong? Thanks in advance.
var map;
require([
    "esri/InfoTemplate",
    "esri/map",
    "esri/dijit/BasemapToggle",
    "esri/dijit/Popup",
    "esri/dijit/Scalebar",
    "esri/dijit/Search",
    "esri/Color",
    "esri/layers/ArcGISDynamicMapServiceLayer",
    "esri/layers/FeatureLayer",
    "esri/layers/ImageParameters",
    "esri/symbols/SimpleFillSymbol",
    "esri/symbols/SimpleLineSymbol",
    "esri/tasks/IdentifyTask",
    "esri/tasks/IdentifyParameters",
    "dojo/_base/array",
    "dojo/dom",
    "dojo/on",
    "dojo/query",
    "dojo/ready",
    "dijit/registry",
    "dojo/dom-construct",
    "dojo/parser",
    "dojo/domReady!"
    function(
  InfoTemplate,
  Map,
  BasemapToggle,
        Popup,
  Scalebar,
  Search,
        Color,
        InfoTemplate,
  ArcGISDynamicMapServiceLayer,
  FeatureLayer,
  ImageParameters,
        SimpleFillSymbol,
        SimpleLineSymbol,
        IdentifyTask,
        IdentifyParameters,
        arrayUtils,
  dom,
  on,
  query,
  ready,
  registry,
  domConstruct,
  parser
          var layer, visibleLayerIds = [], identifyTask, identifyParams;
          var popup = new Popup({
          fillSymbol: new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
            new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
              new Color([255, 0, 0]), 2), new Color([255, 255, 0, 0.25]))
        }, domConstruct.create("div"));
          map = new Map("map", {
            basemap: "topo",
            center: [-123, 49.2],
            zoom:10,
            infoWindow: popup
        //Use the ImageParameters to set the visibleLayerIds layers in the map service during ArcGISDynamicMapServiceLayer construction.
        var imageParameters = new ImageParameters();
  //VFPA Boundary line layers (confirmed and non-confirmed) visible on startup
        imageParameters.layerIds = [0,2];
        imageParameters.layerOption = ImageParameters.LAYER_OPTION_SHOW;
        //can also be: LAYER_OPTION_EXCLUDE, LAYER_OPTION_HIDE, LAYER_OPTION_INCLUDE
          var layerCadastral = new ArcGISDynamicMapServiceLayer("http://cop-gis4:6080/arcgis/rest/services/MOR/MOR_Cadastral_WGS1984/MapServer",
            "imageParameters": imageParameters
          map.addLayer(layerCadastral);
  //every time a layer is clicked, update the layer visibility
        on(dom.byId("chkVFPABoundary"), "change", updateLayerVisibility);
        on(dom.byId("chkMunicipalBoundaries"), "change", updateLayerVisibility);
  on(dom.byId("chkLots"), "change", updateLayerVisibility);
          function updateLayerVisibility () {
            var inputs = query(".list_item");
            var inputCount = inputs.length;
            //Dummy layer - is there a workaround? Setting this to an actual layer means that layer can't be turned off
            visibleLayerIds = [1001];
            for (var i = 0; i < inputCount; i++) {
              if (inputs.checked) {
                visibleLayerIds.push(inputs.value);
            if (visibleLayerIds.length === 0) {
              visibleLayerIds.push(-1);
            layerCadastral.setVisibleLayers(visibleLayerIds);
  //Basemap toggle
  var toggle = new BasemapToggle({
            map: map,
            basemap: "satellite"
            }, "BasemapToggle");
  toggle.startup();
  var scalebar = new Scalebar({
          map: map,
          // "dual" displays both miles and kilmometers
          // "english" is the default, which displays miles
          // use "metric" for kilometers
          scalebarUnit: "dual"
  var s = new Search({
            enableButtonMode: false, //this enables the search widget to display as a single button
            enableLabel: false,
            enableInfoWindow: true,
            showInfoWindowOnSelect: true,
            map: map
         }, "search");
         var sources = s.get("sources");
         //Push the sources used to search, by default the ArcGIS Online World geocoder is included.
         sources.push({
            featureLayer: new FeatureLayer("http://cop-gis4:6080/arcgis/rest/services/MOR/MOR_Cadastral_WGS1984/MapServer/7"),
            searchFields: ["LOT_NO"],
            exactMatch: false,
            outFields: ["*"],
     displayField: "LOT_NO",
            name: "Lots - Lot Number",
            placeholder: "Lot Number",
            maxResults: 6,
            maxSuggestions: 6,
            //Create an InfoTemplate and include three fields
            infoTemplate: new InfoTemplate("Lot Number", "Lot #: ${LOT_NO}</br>Owner: ${OWNER}</br>Title Link: <a href =${TITLE_LINK}>Click to open</a>"),
            enableSuggestions: true,
            minCharacters: 0
         sources.push({
            searchFields: ["OWNER"],
            exactMatch: false,
            outFields: ["*"],
            displayField: "OWNER",
            name: "Lots - Owner",
            placeholder: "Owner",
            maxResults: 6,
            maxSuggestions: 6,
            minCharacters: 0
         //Set the sources above to the search widget
         s.set("sources", sources);
  s.startup();
        map.on("load", mapReady);
        function mapReady () {
          map.on("click", executeIdentifyTask);
          //create identify tasks and setup parameters
          identifyTask = new IdentifyTask(layerCadastral);
          identifyParams = new IdentifyParameters();
          identifyParams.tolerance = 3;
          identifyParams.returnGeometry = true;
          identifyParams.layerIds = [7];
          identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_VISIBLE;
          identifyParams.width = map.width;
          identifyParams.height = map.height;
        function executeIdentifyTask (event) {
          identifyParams.geometry = event.mapPoint;
          identifyParams.mapExtent = map.extent;
          var deferred = identifyTask
            .execute(identifyParams)
            .addCallback(function (response) {
              // response is an array of identify result objects
              // Let's return an array of features.
              return arrayUtils.map(response, function (result) {
                var feature = result.feature;
                var layerName = result.layerName;
                feature.attributes.layerName = layerName;
                if (layerName === 'Lots') {
                  var lotsTemplate = new InfoTemplate("",
                    "Lot #: ${LOT_NO} <br/> Owner: ${OWNER}");
                  feature.setInfoTemplate(lotsTemplate);
                else if (layerName === 'Building Footprints') {
                  console.log(feature.attributes.PARCELID);
                  var buildingFootprintTemplate = new InfoTemplate("",
                    "Parcel ID: ${PARCELID}");
                  feature.setInfoTemplate(buildingFootprintTemplate);
                return feature;
          // InfoWindow expects an array of features from each deferred
          // object that you pass. If the response from the task execution
          // above is not an array of features, then you need to add a callback
          // like the one above to post-process the response and return an
          // array of features.
          map.infoWindow.setFeatures([deferred]);
          map.infoWindow.show(event.mapPoint);
RobertScheitlin__GISP
Laura,
  You were trying to set the IdentifyTasks constructor to a layer object when it needs a url string.
corrected line:
identifyTask = new IdentifyTask(layerCadastral.url);
ChrisSergent
Regular Contributor III
If you use Google Chrome, you can press F12 when you start up your application and then it usually tells you what it's looking for. Most of the time I have seen it as a typo or not declaring a variable with a var and then attempting to use it.
LauraMiles1
Hi Chris, I am using Chrome, and NetBeans. Using F12 unfortunately is not giving me any more enlightenment. I was able to get this esri sample working with my data but when I try to plop that into my existing map, I'm getting this error. I am fairly new to javascript and I think I've put something in the wrong order or something, but I don't know what.
ChrisSergent
Is your site public or can you post your page here: JS Bin - Collaborative JavaScript Debugging ?
LauraMiles1
It's not public nor are my services, but I've posted it and switched back to the service in the ESRI demo: JS Bin - Collaborative JavaScript Debugging
Laura,
corrected line:
LauraMiles1
Thanks Robert, that did it!
So in the ESRI sample, they had set the IdentifyTasks constructor the same way I had - I just switched out my layer for theirs. I'm guessing it is to do with the difference between how they added their layer to the map:
var parcelsURL = "http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/BloomfieldHillsMichigan/Parcels/MapServer";
        map.addLayer(new ArcGISDynamicMapServiceLayer(parcelsURL,
          { opacity: 0.55 }));
and how I added mine:
When I came to the line in the sample
identifyTask = new IdentifyTask(parcelsURL);
I just switched out parcelsURL for my layerCadastral. But in the sample parcelsURL was a variable that held the url string, so I'm guessing that's why it didn't work for me. Thanks both Robert and Chris for your assistance.
