Network Analyst: "Statistics" on the resulting Route
3109
06-11-2015 01:38 AM
ThibautDelaere1
Using Network Analyst (ArcGIS 10.3.1) to solve a Route. I'd like to know some "statistics" of the resulting route. For instance the maximum width a vehicle might be to take that route.
The width of the roads is stored in a field of the road segments.
I know I can do an analysis of the resulting route after the solve, but is there a possibility to do this at once. Like you can accumulate a cost, but can you in some way calculate the max/min value of a field/cost while solving a route?
Regards,
Thibaut
MelindaMorang
No, I don't think it would be possible to calculate the max width during the solve.  Since you don't know what road segments were used until the solve is completed anyway, it would still have to involve some kind of post-processing.  The most seamless way to do this would probably be to build a model or a script that both solves the analysis and calculates the width statistics on the results immediately.  Then you just run that model/script to get your results rather than running the Solve tool.
