marqdouj
CLR Geometry Types - SQL Server
Discussion created by marqdouj on Nov 5, 2010
I am using VS2008 and ArcGIS Engine 10 controls (build 2414).
Is there any way to take advantage of the .Net CLR Geometry types in SQL Server when adding layers to a map?  Currently I am loaded a dataset with the XYs and adding them to a points collection and then adding the points to a map layer - I was hoping there would be an easier way using the geometry type directly?
Doug.
Outcomes
