AnsweredAssumed Answered
Authenticating to internal proxy (407)
Question asked by johnmdye on Jun 10, 2015
Latest reply on Jun 11, 2015 by johnmdye
So, this is literally my first day writing a single line of C# and working with the .NET SDK. The Developer documentation has been really good thus far and I've been able to understand everything pretty well.
Unfortunately, when I got towards the end of the third tutorial, I ran into a problem - my corporate proxy.
Since this is my first day working with C#, I'm not sure how to build a function to use IWA to authenticate to our internal proxy.
Any help or guidance is greatly appreciated.
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Data;
using System.Windows.Documents;
using System.Windows.Input;
using System.Windows.Media;
using System.Windows.Media.Imaging;
using System.Windows.Navigation;
using System.Windows.Shapes;
using Esri.ArcGISRuntime.Controls;
using Esri.ArcGISRuntime.Portal;
using Esri.ArcGISRuntime.WebMap;
namespace FirstApp
    /// <summary>
    /// Interaction logic for MainWindow.xaml
    /// </summary>
    public partial class MainWindow : Window
        public MainWindow()
            InitializeComponent();
        private ArcGISPortal arcGISOnline;
        private ArcGISPortalItem selectedPortalItem;
        // changes the basemap layer
        private void baseMap_SelectionChanged(object sender, SelectionChangedEventArgs e)
            var combo = sender as ComboBox;
            var sel = combo.SelectedItem as ComboBoxItem;
            if (sel.Tag == null) { return; }
            //Find and remove the current basemap layer from the map
            if (mainMap == null) { return; }
            var oldBasemap = mainMap.Layers["BaseMap"];
            mainMap.Layers.Remove(oldBasemap);
            //Create a new basemap layer
            var newBaseMap = new Esri.ArcGISRuntime.Layers.ArcGISTiledMapServiceLayer();
            //Set the ServiceUri with the url defined for the ComboboxItem's Tag
            newBaseMap.ServiceUri = sel.Tag.ToString();
            //Give the layer an ID so it an still be found with the code above
            newBaseMap.ID = "BaseMap";
            //Insert the new basemap layer as the first (bottom) layer in the map
            mainMap.Layers.Insert(0, newBaseMap);
        // searches the portal for content
        private async void SearchButton_Click(object sender, RoutedEventArgs e)
            try
                if (this.arcGISOnline == null)
                    // create the uri for the portal
                    var portalUri = new Uri("https://gis.kdc.capitalone.com/portal/sharing/rest");
                    // create the portal
                    this.arcGISOnline = await ArcGISPortal.CreateAsync(portalUri);
                // create a variable to store search results
                IEnumerable<ArcGISPortalItem> results = null;
                if (this.ItemTypeCombobox.SelectedValue.ToString() == "BaseMap")
                    // basemap search returns web maps that contain the basemap layer
                    var basemapSearch = await this.arcGISOnline.ArcGISPortalInfo.SearchBasemapGalleryAsync();
                    results = basemapSearch.Results;
                else
                    // get the search term provided in the UI
                    var searchTerm = this.SearchTextBox.Text.Trim();
                    var searchItem = this.ItemTypeCombobox.SelectedValue.ToString();
                    // build a query that searches for the specified type
                    // ('web mapping application' is excluded from the search since 'web map' will match those item types too)
                    var queryString = string.Format("\"{0}\" type:(\"{1}\" NOT \"web mapping application\")", searchTerm, searchItem);
                    var searchParameters = new SearchParameters()
                        QueryString = queryString,
                        SortField = "avgrating",
                        SortOrder = QuerySortOrder.Descending,
                        Limit = 10
                    // execute the search
                    var itemSearch = await this.arcGISOnline.SearchItemsAsync(searchParameters);
                    results = itemSearch.Results;
                // show the results in the list box
                this.ResultListBox.ItemsSource = results;
            catch (Exception ex)
                MessageBox.Show(ex.Message, "Error searching Atlas");
        // resets the UI controls to keep them in sync with the currently selected portal item in the ResultsListBox
        private void ResetUI()
            // clear UI controls
            this.SnippetTextBlock.Text = "";
            this.ThumbnailImage.Source = null;
            this.ShowMapButton.IsEnabled = false;
        private void ResultSelectionChanged(object sender, SelectionChangedEventArgs e)
            this.ResetUI();
            // store the currently selected portal item
            this.selectedPortalItem = this.ResultListBox.SelectedItem as ArcGISPortalItem;
            if (this.selectedPortalItem == null) { return; }
            // show the portal item snippet (brief description) in the UI
            if (!string.IsNullOrEmpty(this.selectedPortalItem.Snippet))
                this.SnippetTextBlock.Text = this.selectedPortalItem.Snippet;
            // show a thumnail for the selected portal item (if there is one)
            if (this.selectedPortalItem.ThumbnailUri != null)
                var src = new BitmapImage(this.selectedPortalItem.ThumbnailUri);
                this.ThumbnailImage.Source = src;
            // enable the show map button when a web map portal item is chosen
            this.ShowMapButton.IsEnabled = (this.selectedPortalItem.Type == ItemType.WebMap);
        private async void ShowMapButton_Click(object sender, RoutedEventArgs e)
            // create a web map from the selected portal item
            var webMap = await WebMap.FromPortalItemAsync(this.selectedPortalItem);
            // load the web map into a web map view model
            var webMapVM = await WebMapViewModel.LoadAsync(webMap, this.arcGISOnline);
            // show the web map view model's map in the page's map view control
            this.mainMapView.Map = webMapVM.Map;
Outcomes
