After I published a feature service to ArcGIS Online and moved it into a web map I noticed my field order had been reset. In ArcGIS Desktop I arranged the fields to match the format of ArcPad which our field crew utilizes and to keep the layout familiar in Collector. Due to the number of fields and layers, it would be time intensive to re-arrange all my fields again using the "configure attributes" window within ArcGIS Online. Is there some other way to organize my fields in a web map?
Solved! Go to Solution.
You can manually edit the JSON configuration files for items published on ArcGIS Online using ArcGIS Online Assistant.
is there a way to do this not associated with ArcGIS online? I have the same issue when I publish to ArcServer for use of feature service internally...
