Does anyone know if database views are supported in operations dashboard? I've tried adding a published database view to ArcGIS Online, but when I add the web map to Dashboard, it won't accept the view as a datasource... I have to point out that the Database view is a table.
Solved! Go to Solution.
Hi Lars,
Database views and tables are supported with the Operations Dashboard, but they must be added as External Data Sources. See the section 'External data sources' in the below link:
Data sources in the operation view—Operations Dashboard for ArcGIS | ArcGIS
Hi Lars,
Hi Jake,
Thank you for a fast response, that did the trick! 🙂
Lars
