Raster clip is not honored in AGOL Map
3272
06-08-2015 08:02 AM
MartinSirkovsky
Hi.
I have published an image service where I used polygon to clip a raster image, so the area of the image where there is no content will be clipped. However, when I add the image service to a map in AGOL, the image is not clipped anymore. On the other hand, if I view the service in ArcGIS JavaScript viewer from REST API, or if I add it to ArcMap the image is shown correctly.
I think it used to work some time ago, but not anymore. Any idea why is this happening. The image is cached.
Thank you.
Martin
JakeSkinner
Esri Esteemed Contributor
Hi Martin,
What type of raster are you using for your Image Service (i.e. Mosaic Dataset, JPG, TIFF)?  Also, are you applying the clip using the Clip Function?
MartinSirkovsky
  • The image was imported to SDE. See the image properties in the image below
  • I have used clip function to clip the image
