Where is the install for License Manager 10.3?
6162
7
06-08-2015 07:54 AM
JesseHopkins
New Contributor III
I just mounted the ArcGIS 10.3 .iso, yet I'm not seeing the License Manager 10.3 install folder.  I recall, with previous versions that the 'LicenseManager' folder was located in the 'Installer' folder.  But with 10.3, I'm no longer seeing this. Any idea on its whereabouts? I'm probably just blind.
Thanks.
JayantaPoddar
MVP Esteemed Contributor
Jesse,
I think the License Manager setup is not available in the ISO file available with you. Please get in touch with your local Esri Distributor to avail the setup. Or if your organization has a My Esri account with Administrative privileges, you could download it from there.
Think Location
JayantaPoddar
Hi Jesse,
Could you send a snapshot of the screen (with the folders after the ISO is mounted)?
Think Location
JesseHopkins
New Contributor III
Sure thing.
JayantaPoddar
Jesse,
Think Location
JesseHopkins
New Contributor III
Ok thanks Jayanta.  That's what I figured.
RebeccaStrauch__GISP
Jesse, if you have access to myEsri with download privileges for your account (which I'm assumin gyou do since you have the other files), it is a separate download within the Desktop AND the ArcGIS Server lists (although I'm not sure why it's with the AGS, since it's for desktop CU).
JayantaPoddar
Also a note:
You need license manager if you have concurrent-use (Floating) Desktop licenses.
For Single-use licenses, you could authorize licenses using ArcGIS Administrator, which is a part of Desktop installation.
Think Location
JoeFlannery
Occasional Contributor III
On our server (Windows Server 2012 R2; 64-bit) it is located here:
C:\Program Files (x86)\ArcGIS\License10.3
