Destroy a Div and recreate it with the same name
6200
06-04-2015 01:41 PM
TimWitt2
Hey everybody,
I use the following code to create a map with a legend:
<!DOCTYPE html>
<html>
  <head>
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>NOAA</title>
  <link rel="stylesheet" href="https://community.esri.com//js.arcgis.com/3.12/dijit/themes/claro/claro.css"/>
    <link rel="stylesheet" href="https://js.arcgis.com/3.13/esri/css/esri.css"/>
  <link rel="stylesheet" type="text/css" href="https://timw1984.github.io/agsjs/css/agsjs.css" />
    <style>
    html, body{
        height: 100%;
        width: 100%;
        margin: 0;
        padding: 1px;
        font-family: helvetica, arial, sans-serif;
        font-size: 90%;
  overflow: hidden;
    #borderContainer {
  width: 100%;
  height: 100%;
  #leftPane {
      width: 20%;
  #bottomPane {
  width: 100%;
  #centerPane {
  width: 100%;
  height: 100%;
  #map {
  width: 100%;
  height: 100%;
    </style>
  <script type="text/javascript">
                  var dojoConfig = {
                    paths: {
                            agsjs: location.pathname.replace(/\/[^/]+$/, '') + 'https://timw1984.github.io/agsjs'
     </script>
    <script src="https://js.arcgis.com/3.13/"></script>
    <script>
      var map;
      require(["esri/map", "esri/layers/ArcGISDynamicMapServiceLayer", "dojo/parser", "agsjs/dijit/TOC","dojo/_base/connect","dojo/dom", "dojo/parser","dojo/on", "dojo/_base/Color","dijit/form/Button","esri/layers/FeatureLayer","dojo/dom-construct",
  "dijit/layout/BorderContainer","dijit/layout/ContentPane","dijit/layout/AccordionContainer","dijit/layout/ContentPane", "dijit/layout/AccordionContainer","dijit/form/TextBox","dojo/domReady!"],
   function(Map,ArcGISDynamicMapServiceLayer, parser,TOC,connect,  dom, parser, on,Color, Button, FeatureLayer,domConstruct) {
  parser.parse();
        map = new Map("map", {
          basemap: "topo",
          center: [-95.45, 37.75],
          zoom: 4
  var county;
  var AddedLayer = "";
  var gauge = new ArcGISDynamicMapServiceLayer("http://gis.srh.noaa.gov/arcgis/rest/services/ahps_gauges/MapServer",{
  refreshInterval: 1,
  visible: false
  var radar = new ArcGISDynamicMapServiceLayer("http://gis.srh.noaa.gov/arcgis/rest/services/RIDGERadar/MapServer",{
  refreshInterval: 1,
  visible: false
  var hazard = new ArcGISDynamicMapServiceLayer("http://gis.srh.noaa.gov/arcgis/rest/services/cpc_weather_hazards/MapServer",{
  refreshInterval: 1,
  visible: false
  map.addLayers([radar,hazard,gauge] );
  map.on('layers-add-result', legenddoit);
  function legenddoit(evt){
  if ( AddedLayer == "") {
  var LegendLayers = [{
  layer: hazard,
                    title: "Hazard",
  collapse: true
  layer: radar,
                    title: "Radar",
                    collapsed: true, // whether this root layer should be collapsed initially, default false.
                    slider: true,
  noLegend: true // whether to display a transparency slider.
  layer: gauge,
                    title: "Gauge",
  collapse: true,
  //radar.setVisibleLayers([0]);
  //gauge.setVisibleLayers([0]);
  //hazard.setVisibleLayers([0]);
  toc = new TOC({
  map: map,
                layerInfos: LegendLayers
            }, 'tocDiv');
            toc.startup();
  } else {
  layer: hazard,
                    title: "Hazard",
  collapse: true
  layer: radar,
                    title: "Radar",
                    collapsed: true,
                    slider: true,
  noLegend: true
  layer: gauge,
                    title: "Gauge",
  collapse: true,
  layer: county,
                    title: "County",
  collapse: true,
  toc2 = new TOC({
  map: map,
            }, 'tocDiv');
            toc2.startup();
  var myButton = new Button({
  label: "Click me!",
  onClick: function(){
  if (county !== undefined){
  console.log(county);
  map.removeLayer(county);
            // Do something:
  NeededValue = dom.byId("myURL").value;
  console.log(NeededValue);
  county = new FeatureLayer(NeededValue,{
  outFields: ['*']
  var MyName = county.name;
  map.addLayers([county]);
  AddedLayer = "Gotem";
  domConstruct.destroy("tocDiv");
  dojo.create("div", {id: "tocDiv"}, "LegendInHere");
    }, "progButtonNode").startup();
    </script>
  </head>
  <body class ="claro">
  <div id="borderContainer" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:true, liveSplitters:true">
  <div id="centerPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="splitter:true, region:'center'">
  <div id="map">
  </div>
  </div>
  <div id="bottomPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="splitter:true, region:'bottom'">
  <label for="firstname">Add a layer:</label>
  <input type="text" name="myURL" value="http://gis.brevardcounty.us/gissrv/rest/services/Base_Map/General_WKID102100/MapServer/5"
    data-dojo-type="dijit/form/TextBox"
    data-dojo-props="trim:true, propercase:true" id="myURL" />
  <button id="progButtonNode" type="button"></button><div id="result1"></div>
  </div>
  <div id="leftPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'leading'">
  <div data-dojo-type="dijit/layout/AccordionContainer" style="height: 300px;">
  <div data-dojo-type="dijit/layout/ContentPane" title="Legend" selected="true">
  <div id ="LegendInHere">
   <div id="tocDiv">
  </div>
                </div>
  </div>
  <div data-dojo-type="dijit/layout/ContentPane" title="Pane 2">
  <div id="tocDiv2">
                </div>
  </div>
  </div>
  </div>
  </div>
  </body>
</html>
What I try to accomplish is that if you click on the button, the layer in the textbox is added, the current legend will be destroyed and rebuild with the new layer added. Everything works, if I change the id in line 161 to anything but the id that I destroy a line before. The problem is that I need it to be the same name. any idea what I am doing wrong?
You can test to see what I want it to look like by replacing tocDiv in line 161 and 137 to tocDiv2
Thanks!
Tim
thejuskambi
Have you tried to domConstruct.place with replace option?
thejuskambi
YousefQuran
you can use the appendchild function to add children to a DIV, so each time you add/ remove Child ..
Hope this help you.
Regards,
Yusuf
JakeSkinner
Esri Esteemed Contributor
Hey Tim,
I commented out the following,
toc = new TOC({
    map : map,
    layerInfos : LegendLayers
}, 'tocDiv');
toc.startup();
and the TOC was updated successfully after clicking the button.  So, I believe you have to destroy the TOC widget before creating a new one.   I haven't been able to figure out how to do this.  I've tried using toc.destroy(), but this did not work.
TimWitt2
Jake Skinner​,
Since this is a 3rd party TOC widget I don't think it has a destroy function. I ended up doing it the following way.
<!DOCTYPE html>
<html>
  <head>
    <title>NOAA</title>
    <style>
    html, body{
        height: 100%;
        width: 100%;
        margin: 0;
        padding: 1px;
        font-size: 90%;
  overflow: hidden;
    #borderContainer {
  width: 100%;
  height: 100%;
  #leftPane {
      width: 20%;
  #bottomPane {
  width: 100%;
  #centerPane {
  width: 100%;
  height: 100%;
  #map {
  width: 100%;
  height: 100%;
    </style>
                  var dojoConfig = {
                    paths: {
     </script>
    <script>
      var map;
  parser.parse();
          basemap: "topo",
          zoom: 4
  var county, toc,currentLayer,currentDiv,previouseDiv;
  var click = 0;
  refreshInterval: 1,
  visible: false
  refreshInterval: 1,
  visible: false
  refreshInterval: 1,
  visible: false
  layer: hazard,
                    title: "Hazard",
  collapse: true
  layer: radar,
                    title: "Radar",
                    slider: true,
  layer: gauge,
                    title: "Gauge",
  collapse: true,
  toc = new TOC({
  map: map,
            }, 'tocDiv');
            toc.startup();
  } else {
  var currentDiv = currentLayer;
  layer: hazard,
                    title: "Hazard",
  collapse: true
  layer: radar,
                    title: "Radar",
                    collapsed: true,
                    slider: true,
  noLegend: true
  layer: gauge,
                    title: "Gauge",
  collapse: true,
  layer: county,
                    title: "County",
  collapse: true,
  toc2 = new TOC({
  map: map,
            }, currentDiv );
            toc2.startup();
  label: "Click me!",
  click += 1;
  previouseDiv = currentDiv;
  previouseLayer = currentLayer;
  currentLayer = "layer" + click;
  console.log(currentLayer);
  currentDiv = "<div id=" + currentLayer +">";
  outFields: ['*']
  if (currentLayer == "layer1"){
  domConstruct.place(currentDiv  + "<div>", 'tocDiv',"replace");
  } else {
  domConstruct.place(currentDiv + "<div>", previouseLayer,"replace");
    </script>
  </head>
  <div id="map">
  </div>
  </div>
  </div>
   <div id="tocDiv">
  </div>
                </div>
  </div>
  <div id="tocDiv2">
                </div>
  </div>
  </div>
  </div>
  </div>
  </body>
</html>
Tim
