AnsweredAssumed Answered
ArcMap 10.2.2 Oracle 12c direct connect crash on adding layer to map
Question asked by p_d_austin on Jun 4, 2015
Latest reply on Jun 5, 2015 by p_d_austin
What I'm trying to test is if ArcMap 10.2.2 can connect to an Oracle 12c database that doesn't have SDE installed.
Every time I try to add a layer to the map from an Oracle database base connection the ArcMap crashes and exits without any messages.
I was wondering if this was SDO_GEOMETRY related so I created the simple table below and it crashes too.
CREATE TABLE TEST  (
  ID NUMBER(10) PRIMARY KEY,
  NAME VARCHAR2(20)
Then I tried adding an OBJECTID NUMBER(38) with a unique key at it also crashes.
I also tried a Query Layer with an table with SDO_GEOMETRY and it also crashes.
The SDO_GEOMETRY layers had the SDO_GEOM_METADATA records.
So the question is can ArcMap connect to an Oracle database that doesn't have SDE installed without crashing.
FYI Oracle client is 12.1.0.1.0
Outcomes
