Labeling
4684
11
06-04-2015 02:20 PM
LizHousworth
I'm new at this, so please bare with me.  I was recently asked if I could create a map showing tax parcel color coded in to code classes (ie - > 50,000, 50,000-100,000, etc) and then have the assessment value labeled on each parcel as well.  Our assessment values are in represented into the 100 place (ie - ($)120,200, ($)15,800, ($)267,800, etc.), however they have asked if I can that the labels be 120K, 16K, 268K and so forth.  (essentially rounding the numbers to the nears 1000.  I have found where I can pick how many significant digits should appear, but anything less than 100,000 rounds to the 100 not to the nearest 1000.  (ie - $15,800 remains this as opposed to being rounded to 16,000).
Is this something that is possible to achieve with labeling or is it possible by using the field calculator?  Thanks your any help you can provide me.
curtvprice
MVP Esteemed Contributor
Dynamic labeling using Python should do it for you. Set the label parser to Python and use an expression like this:
"{}K".format(int(round([VALFIELD] / 1000.0)))
You can test this kind of thing at the Python prompt:
>>> "{}K".format(int(round(120800 / 1000.0)))
'121K'
JeffWard
Occasional Contributor III
You can do it both ways.  Dynamic labeling with scripts usually comes with a performance hit since it has to do the job with every feature with every pan, zoom etc.  If you create a field and calculate it, you would only run the script once and label on that field.
Jeff Ward
Summit County, Utah
JeffWard
Are your values text entries or numbers?
Jeff Ward
Summit County, Utah
LizHousworth
They are number values
Liz Housworth
GIS/LIS Technician
Land Information Office
220 E State St, Rm 110
Mauston, WI 53948
(608) 847-9457
liojuneau@co.juneau.wi.us<mailto:liojuneau@co.juneau.wi.us>
JeffWard
If they are integers you can use this to calculate the new text field using the python parser
str(value / 1000) + 'K'
If they are floats
str(int(value) / 1000) + 'K'
Replace 'value' in the above script with '!your_field_name!
Jeff Ward
Summit County, Utah
JeffWard
Keep in mind this doesn't round, it truncates.  So 259,900 would show up as 259K instead of 260K.
Jeff Ward
Summit County, Utah
OwenEarley
In the field calculator change the parser to python and use the following formula:
int(round( !A_Value! , -3)) / 1000
This will give you the rounded value in thousands.
Edit - you will need to replace the !A_Value! with your own field name.
curtvprice
'121K'
JeffWard
That's much better than mine.
Jeff Ward
Summit County, Utah
OwenEarley
Note that the first formula has an extra closing parenthesis after the field placeholder [VALFIELD] that will result in an error:
"{}K".format(int(round([VALFIELD]) / 1000.0)))
Parsing error SyntaxError: invalid syntax (line 1)
Remove the extra closing parenthesis and it works great.
As long as you are not labelling a crazy number of features I would go for the dynamic labelling as you don't need to update calculated fields as your data changes.
