Extract Zip files to one folder
7321
6
06-02-2015 11:01 PM
Yaron_YosefCohen
Occasional Contributor II
Hi everyone,
Continuously to Unzip files from directory tree ,when i try to  extract zip files that contain files with same names in it to one folder , some files got lost because duplication names. I use this code (i work with python 2.7.8 and arcmap 10.3):
import zipfile,fnmatch,os
# EXTRACT ALL ZIP FILES IN DIRECTORY TREE TO ONE SPECIFIC FOLDER
rootPath = r"C:\Project"
pattern = '*.zip'
for root, dirs, files in os.walk(rootPath):
    for filename in fnmatch.filter(files, pattern):
        print(os.path.join(root, filename))
        outpath = r"C:\Project\gis\layers\taba\new"
        print root
        print filename
        zipfile.ZipFile(os.path.join(root, filename)).extractall(r"C:\Project\gis\layers\taba\new")
I don't know how to overcome that issue
Thank for any help
SepheFox
Under your outpath assignment put an if statement.
    for files in arcpy.ListFiles(outpath😞
            If files <> filename:
                print root
                print filename
Or something like that anyway
Yaron_YosefCohen
I get :
DanPatterson_Retired
your if is capitalized
Yaron_YosefCohen
thanks-i've changed that now- nothing happened
>>> ================================ RESTART ================================
JeffWard
Occasional Contributor III
It completed, but your your expression for your if statement was never true, so nothing printed.  It looks like you are reassigning your variable "files" multiple times?  Try a different variable name other than "files" for your third for loop.
Jeff Ward
Summit County, Utah
You are really getting muddled in retaining your paths.  Might I suggest that you do the following
  1. collect the filenames into a list first
  2. remove or rename any duplicates
  3. process the filenames in the previous step last
putting all this into a function will help.  Have a look a my blog post on finding files with a particular file extension.
Before I forget ... # 4 ... Where did that script go?
