Removing thousand seperator in webmap
5418
8
06-01-2015 12:58 AM
ArnoldKuilman
Does anyone know how to remove a thousand separator from the legend in a webmap?
I have a legend with years, and want to remove the thousand separator:
so, away with the comma's in above legend..
JayantaPoddar
MVP Esteemed Contributor
In the Web-Map, go to the Sub-layer (Click the drop-down) > Change Style > Select Drawing Style > Click "Options". Change the labels.
This will get reflected in the legend.
Think Location
JayantaPoddar
Hi Arnold,
Did you publish an MXD to map service for the creation of WebMap. If yes, then open the MXD file. Go to Layer properties > Symbology. Change the labels of symbology to exclude the comma separators.
Think Location
ArnoldKuilman
Unfortunately the labels in the MXD show different formatting from the webmap. I don't have an option to exclude the comma separators in the MXD/layer symbology.
JayantaPoddar
How about enabling time on the layer, and then  overwrite the service?
If that doesn't help, maybe someone can help you configuring the legend widget.
Think Location
JayantaPoddar
In the Web-Map, go to the Sub-layer (Click the drop-down) > Configure Pop-up > Configure Attributes. Slect the Field. Change the format. Uncheck "Use 1000 separator".
Think Location
ArnoldKuilman
Tried that, nicely removes the separator from the pop-up, but not from the legend...:
I will try formatting the field to data, but that is limiting my classification options...
JayantaPoddar
Think Location
ArnoldKuilman
haha, I feel ashamed...
I knew it was easy, but forgot to click on the labels itself.. but thnx:
JayantaPoddar
Thanks to your question, I explored the web-map configurations. I used to ignore these things.
Cheers!!!
Think Location
