Table to csv..
4679
7
05-28-2015 01:39 PM
surens
Is there any tool in Arcmap that is helpful to convert table -> csv or text file..??
Tags (1)
DarrenWiens2
The following Python script will dump the table in the feature layer 'fc' to the csv file 'outCSV':
>>> import csv
... fc = "points"
... outCSV = r'C:/junk/myNewCSV.csv'
... with open(outCSV, 'w') as csvfile:
...     csvwriter = csv.writer(csvfile, delimiter=',')
...     with arcpy.da.SearchCursor(fc,"*") as cursor:
...         for row in cursor:
...             csvwriter.writerow(row)
TimMarquardt1
Yes...just open the attribute table and click on the Table Options menu.....Export... then chose Text File as the file type when you click the folder icon (2nd screen shot)
surens
Thanks for help TIM.. but i would like to know if there is any tool for this in arcmap..??
DarrenWiens2
Here is the help for exporting tables. Hint: change the "Save as type" to 'Text File'.
surens
Thanks for the help Darren but would like to know if there is any tool in arcmap which will help in this issue..??
DarrenWiens2
You could try this tool set, or write your own in Python using the csv library.
surens
Hey Darren, I'm really thankful for the support you have given me but Im currently using 10.3 and when i use Conversion tool -> to excel i get option of .xls file.. can i either get the tool or scrpit for csv..??
DarrenWiens2
>>> import csv
... fc = "points"
