Python Find & Replace WorkspacePaths
3243
05-28-2015 07:49 AM
JohnByrne
Hi all,
I have created a python script that lists all the mxds within a folder directory and then replaces the workspace paths. Now it works correctly for the majority of mxds but on a couple of the mxds it is failing to to replace the workspace path. I would appreciate any advice. I have copied the code into this question but also attached the code. Please note I have more than 1 database connection hence why there is the two find and replace lines for the two connections.
# ##Lists all MXDs within a folder and replaces the SDE connection
for fileName in os.listdir(path):
     fullPath = os.path.join(path, fileName)
     if os.path.isfile(fullPath):
          basename, extension = os.path.splitext(fullPath)
          if extension.lower() == ".mxd":
              mxd = arcpy.mapping.MapDocument(fullPath)
              mxd.findAndReplaceWorkspacePaths(devconn1, conn1)
              mxd.findAndReplaceWorkspacePaths(devconn2, conn2)
              mxd.saveACopy(os.path.join(output, fileName))
             del mxd
RebeccaStrauch__GISP
A couple things to check.
1) check to make sure the values of devconn1 and devconn2 are the exact same in both MXDs and match the variable (i.e. upper/lower case)
2) I had this problem with on and running MXD doctor fixed it  ArcGIS Help (10.2, 10.2.1, and 10.2.2)
Also, I had an issue when trying to run my script thru ArcCatalog 10.2.x  on a mxd saved as 10.3.  (we have a mixed environment)
Hope this helps.  I'm working on a similar project right now....but with many more broken links.
BillDaigle
Occasional Contributor III
If the new data sources are SDE databases, I have had better luck updating each individual layers using replaceDataSource.
Here is a sample:
            for lyr in arcpy.mapping.ListLayers(mxd):
                if lyr.supports("DATASOURCE"):
                    #add some code here to check if the old database is being used
                    #update the layer datasource if necessary
                    lyr.replaceDataSource(newSdeCnctPath, "SDE_WORKSPACE", newDataLayerName, False)
            del mxd
JohnByrne
Hi folks,
Rebecca - Yeah I made all though checks and they were ok.
Bill - your solution worked perfectly until I had an mxd that had more than one database connection in there e.g: DARDOFMD@lpisapp.sde & DARDOFMD@suppapp.sde.
So I get an mxd with only some of the layers replaced and others with broken links!
So close...
