FeatureLayer selectFeatures only displays one feature
3891
05-22-2015 06:56 AM
SarahNoakes1
Occasional Contributor II
I am creating a select features tool.  It will work as follows:
  • The user draws a polygon
  • The draw-end event fires a function that runs an identifyTask to query the visible layers (NB. the identifyTask does NOT return the geometry).
  • The callback function from the identifyTask loops through the results set and creates four arrays - a list of the layers, a list of the ids, a list of the geometry types and a corresponding set of HTML tables detailing the feature attributes for that layer
  • The first array is used to create a drop-down list of layers, and when the selection changes, the display changes to display the relevant table.
So far so straightforward.
I also want the selected features to be highlighted when the layer selection is changed.  To achieve this I have:
  • Created a featureLayer (using the id from the array) with the mode set as MODE_SELECTION
  • Set the selection symbol (uses the geometry type array to determine what type of symbol this should be)
  • Created a queryTask using the geometry of the polygon created in the first step
  • Run the selectFeatures method on the featureLayer using the queryTask
  • Added the featureLayer to the map.
However, only the first feature in each layer is highlighted.  Yet if I look at the query results in the browser console I can see multiple results are returned.
What am I missing?
Sarah Noakes
Cornwall Council
SarahNoakes1
Hi Sarah,
Thanks for getting back to me.  I've figured it out now - It was to do with how I was creating the FeatureLayer.  I had:
featureLayerSelectManyURL = intranetMapServiceURL + "/" + arrTableIds[0];
featureLayerSelectMany = new FeatureLayer(featureLayerSelectManyURL, {mode: FeatureLayer.MODE_SELECTION});
whereas what I needed was:
featureLayerSelectMany = new FeatureLayer(featureLayerSelectManyURL, {mode: FeatureLayer.MODE_SELECTION, outFields: ["*"]});
Goodness only knows why defining the outFields makes as difference - but it does!  Only took the best part of a day ;o)
Cheers,
Sarah.
by Anonymous User
Not applicable
Do you have any code you could share?
I did notice on the API page that for 'MODE_SELECTION' there are specific instructions about adding features:
  1. Call the selectFeatures method.
  2. Listen for the onSelectionComplete event.
  3. Once onSelectionComplete fires, retrieve the selected features using the getSelectedFeatures method.
SarahNoakes1
Hi Sarah,
Cheers,
Sarah.
