Simple Street Index Creator
3661
05-22-2015 01:52 PM
WesMiller
Regular Contributor III
I created this code in hopes of sharing. One of my friends has Windows 8 and Arc 10.2.2, I have Windows 7 and Arc 10.2.1, it works great for me but fails for him below is his error message and below that is the code. Attached is the ode and all the pieces needed to make it run. Any help would be appreciated.
Error Message
Failed script SimpleStreetIndex...
  File
"C:\Temp\WesStreetIndexer\StreetIndexCreator.py", line 91, in
<module>
field_map={'STNAME':fldName ,'PageName':gridField})
  File
"c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\utils.py", line
181, in fn_
    return
fn(*args, **kw)
  File
"c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\mapping.py",
line 515, in ExportReport
    return
report_source._arc_object.ExportReport(*gp_fixargs((report_layout_file,
output_file, dataset_option, report_title, starting_page_number, page_range,
report_definition_query, extent, field_map), True))
RuntimeError: Error in generating report
Failed to execute (SimpleStreetIndex).
Failed at Thu May 21 12:12:18 2015 (Elapsed Time: 1
minutes 0 seconds)
Code
# -*- coding: utf-8 -*-
# Auhor Wes Miller
# Description:
# Selects streets that intersect with grid, creates a street index and exports to pdf
# Import arcpy module
import arcpy,os
# Local variables:
InputStreets = arcpy.GetParameterAsText(0)
InputGrid = arcpy.GetParameterAsText(1)
fldName = arcpy.GetParameterAsText(2)
gridField = arcpy.GetParameterAsText(3)
indexdoc = arcpy.GetParameterAsText(4)
indexname = arcpy.GetParameterAsText(5)
indexLayout = arcpy.GetParameterAsText(6)
#StreetsthatIntersectGrid = "RoadSegment_Layer"
DissolvedStreets = "in_memory\\dissolveStreets"
Streets = "Streets_lyr"
Grid = "Grid_lyr"
outfc =  "in_memory\\joinIndex"
# Process: Make Feature Layer
arcpy.MakeFeatureLayer_management(InputStreets, Streets)
arcpy.AddMessage("Streets layer made")
# Process: Make Feature Layer (2)
arcpy.MakeFeatureLayer_management(InputGrid, Grid)
arcpy.AddMessage("Grid layer made")
# Process: Select Layer By Location
arcpy.SelectLayerByLocation_management(Streets, "INTERSECT", Grid, "", "NEW_SELECTION")
arcpy.AddMessage("Streets selection layer made")
# Process: Dissolve
arcpy.AddMessage("Process: Dissolve")
arcpy.Dissolve_management(Streets, DissolvedStreets, fldName, "", "MULTI_PART", "DISSOLVE_LINES")
if indexname.find('.')<0:
    arcpy.AddMessage("when you don't select a file type pdf is default")
    indexname = indexname+'.pdf'
indexdoc = os.path.join(indexdoc,indexname)
hmpath = os.path.realpath(__file__)
h,t = os.path.split(hmpath)
mxdDoc = os.path.join(h,"StreetIndexCreatorMapDoc.mxd")
mxd = arcpy.mapping.MapDocument(mxdDoc)
df = arcpy.mapping.ListDataFrames(mxd, "*")[0]
# Create a new fieldmappings and add the two input feature classes.
fieldmappings = arcpy.FieldMappings()
fieldmappings.addTable(DissolvedStreets)
fieldmappings.addTable(InputGrid)
jField = fieldmappings.findFieldMapIndex(gridField)
fieldmap = fieldmappings.getFieldMap(jField)
fieldmap.mergeRule = "join"
fieldmap.joinDelimiter = ","
fld_length = fieldmap.outputField
fld_length.length = 4000
if fieldmap.outputField.type.lower() != 'string':
    fld_length.type = 'String'
fieldmap.outputField = fld_length
fieldmappings.replaceFieldMap(jField, fieldmap)
arcpy.AddMessage("Process: Spatial Join")
# Process: Spatial Join
arcpy.SpatialJoin_analysis(DissolvedStreets, InputGrid, outfc, "#", "#", fieldmappings)
addLayer = arcpy.mapping.Layer(outfc)
arcpy.mapping.AddLayer(df, addLayer, "BOTTOM")
if indexLayout == "11 X 17 Landscape":
    rpttemplate = os.path.join(h,"reporttemplate11X17.rlf")
else:
    rpttemplate = os.path.join(h,"reporttemplate.rlf")
arcpy.AddMessage("Creating Report")
lyr = arcpy.mapping.ListLayers(mxd, "joinIndex", df)[0]
arcpy.mapping.ExportReport(lyr,
                           rpttemplate,
                           indexdoc,
                           report_title="Street Index",
del mxd
