query multiple layers
6184
05-21-2015 06:51 AM
PeggyCorey
Can anyone please tell me...  how can you perform a Query/QueryTask on multiple layers?  I know you can perform a Find/FindTask on multiple layers by including multiple numbers in the array: findParams.layerIds = [0,1,2].  But I can't find the equivalent for Query/QueryTask.
Thanks for any help!
JakeSkinner
Esri Esteemed Contributor
Hi Peggy,
Here is a sample that demonstrates this.
JakeSkinner
Hi Peggy,
PeggyCorey
Thanks Jake, Todd and thejus.
All replies were helpful.  I'll try to work my way through using PROMISES - Yikes!
ToddBlanchette
Occasional Contributor II
Hi Peggy,
See if this can help Manage results from multiple queries | ArcGIS API for JavaScript
[Edit: Jake's answer is the same as mine, he fired it up while I was writing this ]
Cheers,
Todd
thejuskambi
Occasional Contributor III
You can not query on multiple layers at the same time. What you could do is query on each layers and combine the results together using the dojo/promise/all as discussed in this thread
How to nest dojo async calls and wait until all are complete
Only instead of layer.queryFeatures your need to use QueryTask for each of the layers.
