export to georeferenced model?
3589
05-20-2015 07:47 AM
MicahTaylor
Occasional Contributor III
I have created a few shapes manually in CityEngine and applied textures.  How can I export these shapes as models that are georeferenced?
For example, I exported my finished shape as a .obj model.  The OBJ looks perfect in the preview window, but when I drag and drop it back in the scene where I created it, it says that the location is too far from the scene to open.
It works fine when I export as an Esri GDB with a multipatch, but it fails to geolocate in other formats.
Thanks!
by Anonymous User
Not applicable
The answer for now is to do what you say in your last sentence. Better options will reveal themselves in the future.
If you are staying inside CityEngine, or ArcGIS, then there shouldn't be any problems using GDB. Let us know if there are problems doing it that way.
MatthiasBuehler
In any case I would try KML. It's the best file format for exchanging georeferenced models between packages that do not support GDBs.
Matthias Buehler
Head of 3D Technologies
twitter: @MattB3D
Garsdale Design Limited
matthias.buehler@garsdaledesign.co.uk
www.garsdaledesign.co.uk
