adding new geometry to featurelayer but doesn't save
2828
05-21-2015 07:18 AM
MohammedKabeer1
Dear all,
i am trying to add polylin, point geometry to feature layer but its not saving in the database. actually data is stored in oracle spatial and i am publishing featurelayer from arcgis server.
after i add geometry it adds but when i refresh it disappear another thing when i add geometry i check in oracle it doesn't insert
here is following code please check it
<!DOCTYPE html>
<html>
  <head>
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <title>Landuse</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.13/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.13/esri/css/esri.css">
    <style>
      html, body {
        height: 100%;
        width: 100%;
        margin: 0;
        padding: 0;
        overflow:hidden;
      #header {
        border:solid 2px #462d44;
        background:#fff;
        color:#444;
        -moz-border-radius: 4px;
        border-radius: 4px;
        font-family: sans-serif;
        font-size: 1.1em
        padding-left:20px;
      #map {
        padding:1px;
        border:solid 2px #444;
        border-radius: 4px;
      #rightPane {
        border:none;
        padding: 0;
        width:228px;
      .templatePicker {
        border: solid 2px #444;
    </style>
    <script src="http://js.arcgis.com/3.13/"></script>
    <script>
      var map;
      var _public = {};
      require([
        "esri/map",
        "esri/toolbars/draw",
        "esri/toolbars/edit",
        "esri/graphic",
        "esri/config",
        "esri/layers/ArcGISDynamicMapServiceLayer",
        "esri/layers/ImageParameters",
        "esri/layers/FeatureLayer",
        "esri/symbols/SimpleMarkerSymbol",
        "esri/symbols/SimpleLineSymbol",
        "esri/symbols/SimpleFillSymbol",
        "esri/dijit/editing/TemplatePicker",
        "dojo/_base/array",
        "dojo/_base/event",
        "dojo/_base/lang",
        "dojo/parser",
        "dijit/registry",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane",
        "dijit/form/Button", "dojo/domReady!"
      ], function(
        Map, Draw, Edit, Graphic, esriConfig,
        ArcGISDynamicMapServiceLayer,
        ImageParameters,
        FeatureLayer,
        SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol,
        TemplatePicker,
        arrayUtils, event, lang, parser, registry
        parser.parse();
        // refer to "Using the Proxy Page" for more information:  https://developers.arcgis.com/javascript/jshelp/ags_proxy.html
        esriConfig.defaults.io.proxyUrl = "/proxy/";
        // This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications.
        esriConfig.defaults.geometryService = new esri.tasks.GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
        map = new Map("map", {
            sliderOrientation : "horizontal"
          var imageParameters = new ImageParameters();
          imageParameters.format = "jpeg"; //set the image type to PNG24, note default is PNG8.
          //Takes a URL to a non cached map service.
          var dynamicMapServiceLayer = new ArcGISDynamicMapServiceLayer("http://192.168.100.72:6080/arcgis/rest/services/ksa_bound/MapServer", {
            "opacity" : 0.5,
            "imageParameters" : imageParameters
        map.addLayer(dynamicMapServiceLayer);
        map.on("layers-add-result", initEditing);
        var landusePointLayer = new FeatureLayer("http://192.168.100.72:6080/arcgis/rest/services/ksa_cities_fl/MapServer/0", {
          mode: FeatureLayer.MODE_SNAPSHOT,
          outFields: ["*"]
        var landuseLineLayer = new FeatureLayer("http://192.168.100.72:6080/arcgis/rest/services/ksa_mot_roads/FeatureServer/0", {
          outFields: ["*"]
        var landusePolygonLayer = new FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Military/FeatureServer/9", {
          outFields: ["*"]
        map.addLayers([landusePointLayer, landuseLineLayer, landusePolygonLayer]);
        function initEditing(evt) {
          console.log("initEditing", evt);
          _public._kabevt=evt;
          // var map = this;
      var currentLayer = null;
          var layers = arrayUtils.map(evt.layers, function(result) {
            return result.layer;
          _public._kablayers=layers;
          console.log("layers", layers);
          var editToolbar = new Edit(map);
          editToolbar.on("deactivate", function(evt) {
            currentLayer.applyEdits(null, [evt.graphic], null);
            console.log("mkabeer",currentLayer );
            _public._kabcurrentLayer=currentLayer.applyEdits(null, [evt.graphic], null);
          arrayUtils.forEach(layers, function(layer) {
            var editingEnabled = false;
            layer.on("dbl-click", function(evt) {
              event.stop(evt);
              if (editingEnabled === false) {
                editingEnabled = true;
                editToolbar.activate(Edit.EDIT_VERTICES , evt.graphic);
              } else {
                currentLayer = this;
                editToolbar.deactivate();
            layer.on("click", function(evt) {
              event.stop(evt);
              if (evt.ctrlKey === true || evt.metaKey === true) {  //delete feature if ctrl key is depressed
                layer.applyEdits(null,null,[evt.graphic]);
                editingEnabled=false;
          var templatePicker = new TemplatePicker({
            featureLayers: layers,
            rows: "auto",
            columns: 2,
            grouping: true,
            style: "height: auto; overflow: auto;"
          }, "templatePickerDiv");
          templatePicker.startup();
          var drawToolbar = new Draw(map);
          var selectedTemplate;
          templatePicker.on("selection-change", function() {
            if( templatePicker.getSelected() ) {
              selectedTemplate = templatePicker.getSelected();
            switch (selectedTemplate.featureLayer.geometryType) {
              case "esriGeometryPoint":
                drawToolbar.activate(Draw.POINT);
                break;
              case "esriGeometryPolyline":
                drawToolbar.activate(Draw.POLYLINE);
                break;
              case "esriGeometryPolygon":
                drawToolbar.activate(Draw.POLYGON);
                break;
          drawToolbar.on("draw-end", function(evt) {
             console.log(evt);
            drawToolbar.deactivate();
            var newAttributes = lang.mixin({}, selectedTemplate.template.prototype.attributes);
            console.log("newAttributes", newAttributes)
            var newGraphic = new Graphic(evt.geometry, null, newAttributes);
            console.log("newGraphic", newGraphic)
            selectedTemplate.featureLayer.applyEdits([newGraphic], null, null);
            _public._kabselectedTemplate=selectedTemplate;
    </script>
  </head>
  <body class="claro">
    <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="gutters:true, design:'headline'" style="width:100%;height:100%;">
      <div data-dojo-type="dijit/layout/ContentPane"  id="header" data-dojo-props="region:'top'">Use ctrl or cmd + click on graphic to delete.  Double click on graphic to edit vertices. </div>
      <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"></div>
      <div id="rightPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'right'">
        <div id="templatePickerDiv"></div>
      </div>
    </div>
  </body>
</html>
here is the console example it shows KSA_MOT_ROADS_ID: 13033
newGraphic Object {geometry: Object, symbol: null, attributes: Object, infoTemplate: undefined, declaredClass: "esri.Graphic"…}_count: 1_extent: Object_graphicsLayer: Object_layer: Object_offsets: Array[1]_shape: Objectattributes: ObjectIGDS_CLASS: nullIGDS_COLOR: nullIGDS_GRAPHIC_GROUP: nullIGDS_STYLE: nullIGDS_WEIGHT: nullKSA_MOT_ROADS_ID: 13033__proto__: Objectgeometry: Object_path: 0cache: Objectpaths: Array[1]spatialReference: Objecttype: "polyline"__proto__: ObjectinfoTemplate: undefinedsymbol: null__proto__: Object
Kabeer
JakeSkinner
Esri Esteemed Contributor
Hi Mohammed,
One issue I see is that you are using a Map Service instead of a Feature Service for your point layer.  Ex:
          outFields: ["*"]
Should be:
var landusePointLayer = new FeatureLayer("http://192.168.100.72:6080/arcgis/rest/services/ksa_cities_fl/FeatureService/0", {
          outFields: ["*"]
MohammedKabeer1
Thank you very much jake
i changed it to feature layer and it works but still my line feature is not saving what could be the problem why the line feature is not saving
thanks
Kabeer
KenBuja
MVP Esteemed Contributor
Is the editing capability turned on for the feature service?
