geocoder limited to 6 results
3521
05-19-2015 03:47 PM
RobbHodges
Occasional Contributor III
Is there a way to change the limit of 6 results when using the geocoder? We are using a composite geocoder that works fine, but it only returns the first 6 results. In some cases we have many more. Anyone know if this is possible and how?
Tags (1)
RickeyFight
MVP Regular Contributor
Robb,
It depends on what  your code looks like but you can add more.
<Number> maxLocationsOptionalMaximum number of results to return. The default is 6.
This can be found here: Geocoder | ArcGIS API for JavaScript
Look at this sample:
Locate points of interest | ArcGIS API for JavaScript
RickeyFight
Robb,
RobbHodges
Rickey,
Thank you! This has been bugging me for awhile. I'm still relatively new to the web appbuilder, but I should be able to figure it out from here. More than anything, I'm just glad to hear that it's possible.
