AnsweredAssumed Answered
Cannot make datum transformation by changing data frame properties
Question asked by Ditlev on May 18, 2015
Latest reply on May 18, 2015 by Ditlev
Hey everyone.
I have a Modis LUCL map (MCD12C1) which is having the following datum.
Datum: D_Not_specified_based_on_Clarke_1866_spheroid
I want to transform this datum into the datum used by my data frame which is D_WGS_1984
I have tried to do this through data frame properties (Coordinate system --> transformations). However, when I select convert from and into the above Datums, and press ok, nothing changes. In "using", i have to select and create a new geographic transformation.
What can be the reason for this? Is there some other way to do this?
Thank you very much!
Best regards
Ditlev Reventlow.
Outcomes
