AnsweredAssumed Answered
Can't use lookup function and cant create uniques values
Question asked by Ditlev on May 17, 2015
Latest reply on May 18, 2015 by Ditlev
Hey everyone.
I am using a Field from a raster dataset in raster calculator. Because this field is not selected by Default, I have to use the lookup function to make the program select this field.
I type the following in raster calculator.
Lookup("ESACCI-LC-L4-LCCS-Map-300m-P5Y-2010-v1.4.tif","Perc_fores").
"Perc_fores" is a long integer that I have created and this is the field that I need for my analysis. However, this gives an error in the look up function.
When I try the same for the "Count" field so written as below:
Lookup("ESACCI-LC-L4-LCCS-Map-300m-P5Y-2010-v1.4.tif","Count")
, then it works fine.
But if I try on the "Value"
Lookup("ESACCI-LC-L4-LCCS-Map-300m-P5Y-2010-v1.4.tif","Value")
, then it doesn't work either.
I have checked that everything is correctly spelled and so on. What can the reason for this be? I have used the lookup function a thousand times and it has always worked.
Thank you very much.
best regards
Ditlev Reventlow.
Outcomes
