This is a very basic script, but I can't figure out why it's not finding my GO button! I've looked it over many times and can't spot anything out of order in terms of my requires. I thought at first there was something wrong with the function I was calling, so I made a 2nd one that's still just empty. I have a very convoluted where clause to execute and I'm attempt to let the user enter the codes, but I can't get past creating the button to execute it!
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10"> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>Search</title> <link rel="stylesheet" href="https://js.arcgis.com/3.13/dijit/themes/claro/claro.css"/> <link rel="stylesheet" type="text/css" href="https://js.arcgis.com/3.13/esri/css/esri.css"/> <style type = "text/css"> #mapDiv, .map { height: 500px; width: 500px; } </style> <script type="text/javascript"> var dojoConfig = { parseOnLoad: false, async:true }; </script> <script type="text/javascript" src="https://js.arcgis.com/3.13/"></script> </head> <body class="claro"> <script type=text/javascript> var pathName = "https://ogitest.oa.mo.gov"; require(["dojo/parser","esri/map", "esri/layers/FeatureLayer", "esri/layers/ArcGISDynamicMapServiceLayer", "esri/tasks/query", "dojo/on", "dojo/dom", "dijit/registry", "dijit/form/Button", "dojo/domReady!" ], function( parser, Map, FeatureLayer, ArcGISDynamicMapServiceLayer, Query, on, dom, registry, Button){ parser.parse(); var map = new Map("mapDiv", { center: [-92.593, 38.5], zoom: 7, basemap: "topo" }); var pointLayer = new FeatureLayer(pathName + "/arcgis/rest/services/DSS/medProvider/MapServer/0", { mode: FeatureLayer.MODE_ONDEMAND, id: "pointLayer", outFields: ["*"] }); var countyLayer = new ArcGISDynamicMapServiceLayer(pathName + "/arcgis/rest/services/BaseMap/county_simple/MapServer", { id: "countyLayer" }); pointLayer.on('load', executeSearch); map.addLayers([countyLayer, pointLayer]); function executeSearch(){ // console.log('in executeSearch'); // var provCode = dom.byId('txtProvider').value; // var specCode = dom.byId('txtSpecialty').value; var query = new Query(); // var whereClause = "Provider_Type IN ('" + sortedString + "')"; // var whereClause = "ID_PROV_TYPE_FK IN ('40','74') AND ID_SPECIALTY_FK IN ('73','74','75','83','84','85')"; var whereClause = "ID_PROV_TYPE_FK IN ('35') AND ID_SPECIALTY_FK IN ('E5')"; // var whereClause = "ID_PROV_TYPE_FK IN ('" + provCode + "') AND ID_SPECIALTY_FK IN ('" + specCode + "')"; // var whereClause = "1=1"; query.where = whereClause; pointLayer.setDefinitionExpression(whereClause); var gridQuery = new Query(); pointLayer.selectFeatures(gridQuery, FeatureLayer.SELECTION_NEW, function(results) { dom.byId('infoDiv').innerHTML = results.length + " features found"; if ( results.length > 0 ) { var feature = results[0]; } else { console.log("error in pointLayer selection"); } }); } function executeBtnSearch(evt){ console.log('in executBtnSearch'); } //event listener registry.byId("btnGo").on("click", executeSearch2); }); </script> <div id="mapDiv"> <input id="txtProvider" dojo-data-type="dijit/form/TextBox" placeHolder='Enter Provider Code'> </input> <input id="txtSpecialty" dojo-data-type="dijit/form/TextBox" placeHolder='Enter Specialty Code'> </input> <button id="btnGo" dojo-data-type="dijit/form/Button"> GO </button> </div> <div id="infoDiv">Features </div> </body> </html>
Solved! Go to Solution.
Tracy,
For your button try:
var btnGo = dom.byId("btnGo"); on(btnGo, "click", executeSearch);
Regards,
Tom
Tracy,
Regards,
Tom
Tracy,
The reason Toms response is correct is because registry.byId is for widget and your button is not a widget, it is just a standard dijit button.
All this time I had it in my head that if I was using dojo components I needed to use 'registry.byId'. In the case of my button, it's even more confusing to me, since it's typed as dijit/form/Button.
Tracy,
Sorry, I have added to your confusion by saying dijit when I should have said widget.
dijit/registry stores a collection of all the dijit widgets within a page. It is commonly used to retrieve a reference to a widget from a related piece of data (such as the widget’s DOM node or ID)
I hate to reopen a closed thread, but I'm having the same issue as before, but this time it's still not finding it.
This is how my button is defined:
<button id="btnMap" data-dojo-type="dijit/form/Button"> View Map </button>
This is the click event I'm trying to add:
var btnMap = dom.byId('btnMap'); on(btnMap, "click", function (evt){ console.log("button has been clicked") window.open(pathName+"/DHSS/WICprovider/index.html"); });
It works if I don't have the data-dojo-type defined, but I want the styling that comes with it.
I have a button
<button data-dojo-type="dijit/form/Button" type="button" title="Project information" id="btnHelp"> Project information </button>
that I wire up using registry and it works properly. However, I have this in the ready function (using "dojo/ready")
ready(function () { registry.byId("btnHelp").on("click", function () { registry.byId("dialogWelcome").show(); }); });
Tracy,
It appears just to be a typo. Your button definition should be dojo-data-type and not data-dojo-type.
Regards,
Tom
That can't be right. That's the order from the dojotoolkit documentation. I have various other content panes all with data-dojo-type and they work.
Tracy,
I had just set up a quick demo using your code above and adding the new button. All of the the above elements used dojo-data-type. Your btnMap used data-dojo-type. You can view it at: http://gis.yakimawa.gov/demo/buttonevent.html
Regards,
Tom
