the result of route analysis doesn't match with the base map
3445
05-12-2015 12:51 AM
TerryKwok
Hi everyone!
     I use the tool on arcgis online to set the source. destination and generate the traffic route. Once the route is generated, it did not match the base map. I used the ESRI-default  for route analysis. I tried many different layer on the esri gallery. They don't match either. I wanted to find out a layer that match the route analysis result for esri-default route service. Can anyone help me? Thanks a lot !
     Terry
