SOE - Can't launch debugging due to no attachemnt on the ArcSOC
2882
05-11-2015 05:56 AM
ShaningYu
After creating a .soe,, adding it to the ArcGIS Server, the VS JIT Debugger pops out.  Like I did on other .soe's, I clicked my project / New VS as the Possible debugger, and then click Yes to continue.  Then after I clicked the Attach button, the AOC is running on VS.  Unfortunately, my project is NOT attached on the ArcSOC.  I could not find anything wrong in my code, and there is nothing in the logs.  Appreciate if you can hint me how to do.
Tags (1)
ShaningYu
This problem was found to be the conflict between versions (ArcGIS 10.2 but ArcObjects SDK for .Net Framework 10.1.  After I installed SDK 10.2, the problem was gone.
