Network Analyst
2067
10-06-2009 10:39 AM
JaySandhu
Original Post Date: Oct 06, 2009 11:39 AM PDT
The Network Analyst in 9.4 has a lot of new functionality. Let us know your experiences in using it!
Jay Sandhu
JaySandhu
In 9.4 the Network Analyst has been updated with a number of new features and numerous enhancements. The new features are:
A new Location-Allocation solver for site selection including support for gravity (Huff) models
Enhanced barrier support for using line and polygon barriers
Lot of enhancements to the Network Dataset such as:
  • Incremental Rebuild based on dirty areas
  • 3-D Network connectivity
  • Versioned network datasets in SDE
  • Historical traffic Data
  • Dissolve network tool for networks in a geodatabase with support for hyper edges to enable high-performance routing
  • Better storage of network elements on disk in the network dataset to support faster routing performance
Numerous other improvements such as in loading locations, better no u-turn support, driving directions, geoprocessing, scalability, SDK, Tutorials and documentation.
Jay Sandhu
NiallCarter
New Contributor III
HI
The help for multiple breaks specifies that each route can have 'at most one breal' although I was under the impression that multiple breaks was a new feature of 9.4?
Each time I try to add another break into the VRP the solve fails. Any clues?
Another new function - that of the ability to leave the start or end location empty - is advirtised to be included at 9.4. Again when I try to leave either of these values blank my VRP solver fails. Any ideas?
Niall Carter
NaAn
Hi Niall,
ESRI will introduce the multiple breaks function in 9.4 beta 2 which will be released in late January. With the new function, user will be able to add up to 5 breaks.
Virtual depot function was introduced in 9.3.  User is allowed to leave EITHER �??StartDepotName�?� OR �??EndDepotName�?� blank for a route, but not both. It should work well. Could you please let me know what warning/error message you got?
Thanks.
Anna
NiallCarter
New Contributor III
Hi Anna
Apologies since re running my analysis I have managed to get the VRP with either start or end depots as null to now work.
I will wait for beta 2 before testing the multiple breaks. Is there a doc somewhere which indicates which functionality is contained in beta 1 versus beta 2? Clearly I was not aware that multiple breaks came in the full function beta 2 release.
Ta,
Niall
