Converting ITRF 2005 to WGS 84 (ArcMap 10.2.2)
7159
6
05-07-2015 04:52 AM
ALIHash1
Dear all,
I have a excel file with xy coordinates for points in the ITRF 2005 format. I am trying to convert the xy coordinates to xy coordinates in the  WGS 84 format. Any ideas how i can go about this or the conversion. Please take a look at the attached excel table of my ITRF 2005 xy Coordinates that i need to convert to xy WGS 84 values.
ToddBlanchette
Occasional Contributor II
Hi Ali,
I'm taking a look at your data, and the points are projected (looks like UTM, but they're definitely not Lat/Long).  Do you know the original projection in order to reproject them to WGS84?
Other than that, the step by step is:
1) Set dataframe projection to match your source data (Projection/ITRF2005 datum)
2) Add your XY data to the map
3) Export as a new feature class or shapefile
4) Run 'Project (Data Management)' tool to project your shapefile/feature class to your new projection and save it.
5) Create new XY fields containing the new coordinates of your new projected feature class/shapefile
6) If you require it, export them to a new excel table.
Todd
ALIHash1
Dear Todd,
Thank you for the response. I followed what you outlined earlier but i keep getting an error when i try Project the ITRF 2005 Point feature class to WSG84 UTM Zone 35S using the data management Project tool. It gives an error with feature class empty.
ALIHash1
Thank you Todd and Melita i finally got it projected in WGS84.
Regards
Ali
SepheFox
I'm glad you solved your problem Ali. Do you mind marking this question as answered? Thanks!
nurullah_sen
hi.Can you explain to me how to solve problem of the converting ITRF 2005 to WGS 84 ?
MelitaKennedy
Esri Notable Contributor
Your original points are in UTM coordinates or possibly Gauss-Kruger. We don't have any geographic/datum transformations between ITRF and WGS 1984 because WGS 1984 is kept more or less coincident with ITRF. So, I would follow the steps 1-3 Todd Blanchette​  but immediately set the coordinate system of the XY data in ArcMap to WGS 1984 whatever-zone-the-data-is-in. If you need WGS 1984 decimal degree values, you can then continue with steps 4-6.
Melita
