How to select a word between parenthesis in a attribute table ?
5103
9
05-07-2015 12:53 PM
FatmaŞenol
Occasional Contributor II
Dear members,
I have a quick question and hope if you could kindly share your suggestions.
I'm trying to select words between parenthesis (i.e (Izmir). I've searched Geonet
for this specific task but ended up with no luck. I'm sending the screenshot
of the table.  Thank you in advance.
Regards
JakeSkinner
Esri Esteemed Contributor
Hi Omur,
You can accomplish this using a wildcard.  For example, to do this with a feature class:
Place LIKE '%(Izmir)%'
See the section 'Search Strings' in the below link:
Building a query expression—Help | ArcGIS for Desktop
VinceAngelo
This forum is for help with GeoNet itself.  In order to move this question to the correct forum you'll need to specify what Esri product you are using, the release of that product, and the programming language you are using.
- V
KenBuja
MVP Esteemed Contributor
It has been moved.
FatmaŞenol
Hello Vince,
Please accept my apology for posting to wrong channel.
DarrenWiens2
MVP Honored Contributor
edit: the following is to extract the word between parentheses. If you are looking to simply select features based on the word between parentheses, follow Jake's advice below.
Using Python in field calculator:
!Place!.split('(')[1].split(')')[0]
Basically, split your original string by the character '(', take the second part of that, split it by ')', and take the first part of that.
JakeSkinner
Hi Omur,
FatmaŞenol
Hello Jake,
Thank you for your suggestion. It worked . After I posted my original question I realized
that I also need to copy the words between the parenthesis to a new field. Could it be done
using Field Calculator ?
JakeSkinner
Yes, after you make the selection use the syntax Darren specified in the field calculator.
Be sure to check 'Python' at the top of the Field Calculator.
FatmaŞenol
Hi Jake,
Thank you for your help. I just have  one more question. How can I
copy all the words  between parenthesis not only the selected records ?
JakeSkinner
You can do this by not having any features selected and using a try/except statement since not all of the rows contain values with parentheses.  Ex:
It will try the code, but if the row does not contain any parentheses, it will pass this row rather than creating an error.
