AnsweredAssumed Answered
Corner lot test not working
Question asked by trilec on May 5, 2015
Latest reply on May 7, 2015 by trilec
imports fail to load
reports "no such function" : ? streetWidth()
file Colors.cga contains:
SNOW -->color("#FFFAFA")
real bummer if this is the case, as you cant test a corner lots if you have imports
this code was the default example to test corners, WHY this is not a standard "geometry.isCorner" is beyond me...
version "2014.0"
import col  : "Colors.cga"  <<<<< error "no such function" : ? streetWidth()
#BuildingVariables
attr    BldMasterHeightMin = 10
attr    BldMasterHeightMax = 30
attr BldIsCorner =  false
attr streetWidth(i) =  0  <<<<<the offending line needed for index Recursion
Lot-->
    CornerRecursion(geometry.nVertices - 1, 0)
CornerRecursion ( edgeID, nStreetEdges ) -->
    case edgeID >= 0 :
        case streetWidth(edgeID) > 0 :
            #print (edgeID)
            CornerRecursion ( edgeID - 1, nStreetEdges + 1 )
        else:
            #print (edgeID)
            CornerRecursion ( edgeID - 1, nStreetEdges )
    else:
        case nStreetEdges >= 2 :
            #set(BldIsCorner, true)
            doLot #corner Lot
        else:
            #set(BldIsCorner, false)
            doLot #Not corner lot
doLot-->
    extrude(rand(BldMasterHeightMin, BldMasterHeightMax))
    comp(f) { top: doTop | all: doFacard }
doTop-->
    roofHip(20)
    col.PINK
doFacard-->
    col.PINK
Outcomes
