Adding ArcGIS search service to geoportal
3834
05-05-2015 06:54 AM
EricBowman2
Have installed geoportal 1.2.5 and is up and running. Also, have ArcGIS Server 10.2.1.  The documentation says that a search service can be used, but I haven't seen where or how to set this up. If you have any suggestions or comments on how to do this, I would greatly appreciate it.
Eric
ErikLima
New Contributor III
Hi, Eric.
I have created that federated search, the link to instructions at wiki is: geoportal-server/components/server/FederatedSearch at master · Esri/geoportal-server · GitHub
Best regards,
Erik Lima
EricBowman2
Hi Eric,
Thanks for the link. We don't have portal. So, we want to go the other way. We want to bring in our search service into the geoportal results.  Is this possible?
Eric
RexNeville1
Hi Eric,
If you would like the Geoportal server to read and index services and metadata from your ArcGIS server the instructions are here - Register ArcGIS for Server with the Geoportal · Esri/geoportal-server Wiki · GitHub
Regards,
Rex.
Working on GeoDiscover Alberta for the Government of Alberta
