AnsweredAssumed Answered
incorrect edit version type
Question asked by imgooch on May 4, 2015
Latest reply on May 5, 2015 by canadiantodd
I'm trying to create a geometric network and see if it suits my needs but am having an issue.  I created it using the tool but when I try to start an edit session it says "incorrect edit version type".  The data is NOT versioned.  So if i try to edit normally I get the error that says the data is not registered as versioned and must change the editor options to uncheck editing of versions (wish this would remember so I wouldn't have to uncheck it every time I edit!!).....but then I get the other error.  So no matter what I can't edit the data.  I don't understand what is going on here.
I searched around and have found no answer to this issue at all.  I've tried restarting the database, recreating the network, restarting ArcMap, and disco/reconnecting the db.
The data is in SDE (SQL Express), in it's own dataset.  I'm using ArcMap 10.3.
Any suggestions?
Thanks!
Outcomes
