Why don't Python add-ins provide a dialog box for user input?
7100
11
05-04-2015 10:53 AM
IanBroad
New Contributor III
Currently, we have:
OpenDialog
SaveDialog
GPToolDialog
MessageBox
But there's no way to actually get user input. Why is this? Does ESRI plan on eventually providing a way to get user input?
JamesCrandall
MVP Frequent Contributor
What are the input requirements?
One solution is to create a new tool in a Toolbox.tbx and setup input parameters.  Then you can open/popup this as a UI with:
pythonaddins.GPToolDialog(r'<path>\<toolboxname.tbx>', '<tool name>')
Here's how it might look hooked into an add-in with a button tool:
class ButtonClass_CreateSHP(object):
    """Implementation for my_addin.button_1 (Button)"""
    def __init__(self):
        self.enabled = True
        self.checked = False
    def onClick(self):
        pythonaddins.GPToolDialog(r'<path>\<toolboxname.tbx>', 'CreateShapefile')
IanBroad
New Contributor III
Yeah, I've thought about that. I just see it as kind of a clunky, unattractive way of doing it. I'd be nice to just have a dialog box that the user could enter a value into- it seems simple enough.
One example is that I'd like to have a button that when clicked takes an OID of a specific layer for input, and zooms to that feature based on the OID entered. Easy enough to do, but the whole user input part is missing.
JamesCrandall
I think you can accomplish this with the Tool Validator and set the input parameter when you launch the tool:
pythonaddins.GPToolDialog(r'<path>\<toolboxname.tbx>', '<tool name>', '<arg1>', '<arg2')
IanBroad
New Contributor III
Right. I guess my main point is that I'd like to have a way of getting user input without needing to use an existing toolbox.
JamesCrandall
Tkinter maybe?  Not sure how well it behaves though.
TI
Occasional Contributor II
ArcMap does not play nicely with any Python modules that have a non-ArcMap GUI.  I've tried Tkinter and others, before finding that it just randomly crashes ArcMap.  Subsequent Googling found that other people have concluded that non-ArcMap GUI's in Python add-ins clash with ArcMap and cause it to crash.
RebeccaStrauch__GISP
Do you have it in a Toolbox?  It's easy to create a Python addin from a tools box that will have a user interface.  For what it's worth, I have some steps listed in a power point Python add-ins vs. .NET add-ins?
And there is a tech session Python Add-ins: Tips and Tricks   that might be worth checking out.
DanPatterson_Retired
Rebecca, Jason's presentation is still just a bunch of blank screens with titles..I suspect some iThingy problem.  There are still a bunch of posts on that thread...Do you have a link that can be read with all content?
Dan, your right. I looked at it a while ago and just copied the link.  I'll edit my post.
