Greetings! I used the example here - http://blogs.esri.com/Dev/blogs/arcgisserver/archive/2009/12/14/Add-a-Zoom-button-to-a-DataGrid.aspx - to set up a datagrid to display my results. This works great, but I would like to change the tooltip that displays when you hover over the column name. In the example, when you hover over the magnifying glass in the column header, a plus sign (+) appears. I would like to change this to something more meaningful - like "Zoom." I have searched and searched, but can not find where this is set. Does anyone know how I can change it? Thanks! ~Stephanie :confused:
YES!! That was it. I knew it had to be something simple. One of the drawbacks of copying and pasting code from examples...I didn't even see that in there. Thank you!!!
