How to set permissions at the level of fields?
2338
04-29-2015 01:04 AM
LakshmanGanglani
I have been looking up to ESRI if they can provide a solution through ArcMAP for the above requirement. I have already reviewed an article on the above (refer URL), but is there any possibility that ESRI is working on this in distant future. Any plans ?
I believe this is the most important requirement considering data security and management point of view.
LD Ram.
BlakeTerhune
MVP Regular Contributor
Our solution is to break the attribute table apart and put the secured fields in a separate table that is related to the master feature class. You can then set all the necessary permissions on the related table(s).
LakshmanGanglani
Thanx Blake. I wanted it to be managed on a featureclass somehow.
