Adding the Geocoder Widget
4017
04-28-2015 07:16 PM
SteveCline
I am somewhat new to javascript and I am having some difficulty bringing this function into my existing project: Geocoder widget | Guide | ArcGIS API for JavaScript
I would like to add the geocoder widget to a project I am working on but as soon as I begin altering the "require" lines in my js file I start losing parts of the app.  Is there a good resource available or can someone guide me through the process and explain the best way to do this?
Any assistance is greatly appreciated.
Here is my HTML: (I realize that the layers are all the same tiled service.  I have not created my additional layers yet.)
<!DOCTYPE html>
<html>
<head>
  <title>EarthSurveyor</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.13/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.13/esri/css/esri.css">
  <link rel="stylesheet" type="text/css" href="MapLab3.2.css">
  <link href='http://fonts.googleapis.com/css?family=Oswald' rel='stylesheet' type='text/css'>
  <script src="http://js.arcgis.com/3.13/"></script>
  <script src="MapLab3.2.js"></script>
</head>
<body class="claro">
<div id="search"></div>
  <div id="appTitleContainer">EarthSurveyor - World Mapping Lab</div>
<!-- place an html tag here -->
  <div id="appReturnLink">Back to Main</div>
  <div id="content" data-dojo-type="dijit/layout/BorderContainer"
     data-dojo-props="design:'headline', gutters:true"
     style="width: 100%; height: 100%; margin: 0;">
  <div id="rightPane"
       data-dojo-type="dijit/layout/ContentPane"
       data-dojo-props="region:'right'">
    <div data-dojo-type="dijit/layout/AccordionContainer">
      <div data-dojo-type="dijit/layout/ContentPane" id="legendPane"
           data-dojo-props="title:'Legend', selected:true">
        <div id="legendDiv"></div>
      </div>
           data-dojo-props="title:'Layers'">
        <span style="padding:10px 0;">Click to toggle the visibility of the layers</span>
        <div id="toggle" style="padding: 2px 2px;"></div>
      </div>
    </div>
  </div>
  <div id="map"
       data-dojo-props="region:'center'"
       style="overflow:hidden;">
  </div>
  </div>
</body>
</html>
Here is my js:
var map;
    require([
      "esri/map",
      "esri/arcgis/utils",
      "esri/dijit/Legend",
      "esri/layers/ArcGISTiledMapServiceLayer",
      "esri/layers/ArcGISDynamicMapServiceLayer",
      "dojo/dom",
      "dojo/dom-construct",
      "dojo/parser",
      "dojo/_base/array",
      "dijit/form/CheckBox",
      "dijit/layout/AccordionContainer",
      "dijit/layout/BorderContainer",
      "dijit/layout/ContentPane",
      "dojo/domReady!"
      function (
        Map, utils, Legend, ArcGISTiledMapServiceLayer, ArcGISDynamicMapServiceLayer, dom, domConstruct,
        parser, arrayUtils, CheckBox
        parser.parse();
        var legendLayers = [];
        map = new Map("map", {
          basemap: "topo",
          center: [10, 23],
          zoom: 2
// duplicate this for each layer - use dynamic layer service for those types
        var LADALandUse = new ArcGISTiledMapServiceLayer("http://tiles.arcgis.com/tiles/HVjI8GKrRtjcQ4Ry/arcgis/rest/services/LADA_Land_Use_Systems/MapServer", {
        legendLayers.push({ layer: LADALandUse, title: 'Land Use' });
//         to here
        var WWFTerEco = new ArcGISTiledMapServiceLayer("http://tiles.arcgis.com/tiles/HVjI8GKrRtjcQ4Ry/arcgis/rest/services/LADA_Land_Use_Systems/MapServer", {
        legendLayers.push({ layer: WWFTerEco, title: 'WWF Terrestrial Ecoregion' });
        var climateLayer = new ArcGISTiledMapServiceLayer("http://tiles.arcgis.com/tiles/HVjI8GKrRtjcQ4Ry/arcgis/rest/services/LADA_Land_Use_Systems/MapServer", {
        map.on('layers-add-result', function () {
          var legend = new Legend({
            map: map,
            layerInfos: legendLayers
          }, "legendDiv");
          legend.startup();
        legendLayers.push({ layer: climateLayer, title: "Climate" });
        map.addLayers([ climateLayer, LADALandUse, WWFTerEco ]); /*add the layer var here*/
          //add check boxes
          arrayUtils.forEach(legendLayers, function (layer) {
            var layerName = layer.title;
            var checkBox = new CheckBox({
              name: "checkBox" + layer.layer.id,
              value: layer.layer.id,
              checked: layer.layer.visible
            checkBox.on("change", function () {
              var targetLayer = map.getLayer(this.value);
              targetLayer.setVisibility(!targetLayer.visible);
              this.checked = targetLayer.visible;
            //add the check box and label to the toc
            domConstruct.place(checkBox.domNode, dom.byId("toggle"), "after");
            var checkLabel = domConstruct.create('label', {
                'for': checkBox.name,
                innerHTML: layerName
              }, checkBox.domNode, "after");
            domConstruct.place("<br />", checkLabel, "after");
Here is the css:
html, body {
      height: 92%;
      width: 98%;
      margin: 1%;
    #rightPane {
      width: 20%;
    #legendPane {
      border: solid #97DCF2 1px;
    #appTitleContainer {
      width:75%;
      height:5%;
      margin: 1%;
      font-size: 22px;
      font-family: 'Oswald', sans-serif;
      float:left;
    /*this needs to allign with the one above it */
    #appReturnLink {
      right: 20%;
      height:5%;
      margin: 1%;
      font-size: 22px;
      float: right;
    #search {
      display: block;
      position: absolute;
      z-index: 3;
      top: 20px;
      left: 75px;
KenBuja
MVP Esteemed Contributor
One thing you have to remember about AMD (Asynchronous Module Definition) is that the arguments in the "function" callback are positional, meaning they have to be in the same order as the modules that are loaded in "require"  section.
For example, if you tried to do something like this to add the "Search" tool, you'll run into errors
    require([
      "esri/dijit/Search",
      "esri/map",
      "dojo/dom",
      "dojo/parser",
      "dojo/_base/array",
      "dojo/domReady!"
      function (
        parser, arrayUtils, CheckBox, Search
Since the "esri/dijit/Search" module is first, the argument "Map" would be assigned to it, which would result in an error when you try to create a new map.
          basemap: "topo",
          center: [10, 23],
          zoom: 2
This would be the proper way to add the additional module. Note that the modules that don't need arguments are always after the modules that do need arguments ("dijit/layout/AccordionContainer" through "dojo/domReady!").
    require([
      "esri/map",
      "dojo/dom",
      "dojo/parser",
      "dojo/_base/array",
      "dojo/domReady!"
      function (
KenBuja
    require([
      "esri/map",
      "dojo/dom",
      "dojo/parser",
      "dojo/_base/array",
      "dojo/domReady!"
      function (
          basemap: "topo",
          center: [10, 23],
          zoom: 2
    require([
      "esri/map",
      "dojo/dom",
      "dojo/parser",
      "dojo/_base/array",
      "dojo/domReady!"
      function (
SteveCline
Thank you - that helps
