AnsweredAssumed Answered
i am un able to know what is error in this code....the result is not shown when the code is run..
Question asked by aneeshasatya on Apr 27, 2015
Latest reply on Apr 27, 2015 by rastrauch
<%--<%@ Page Language="C#" AutoEventWireup="true" CodeBehind="population.aspx.cs" Inherits="WebApplication3._Default" %>--%>
<!DOCTYPEhtml>
  <html>
  <head>
    <metahttp-equiv="Content-Type"content="text/html; charset=utf-8">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <metaname="viewport"content="initial-scale=1, maximum-scale=1,user-scalable=no">
<title>Nalgonda point data popup</title>
        <linkrel="stylesheet"href="http://js.arcgis.com/3.13/dijit/themes/claro/claro.css">
        <linkrel="stylesheet"href="http://js.arcgis.com/3.13/esri/css/esri.css">
<style>
            html, body,
            #map
            .map.container {
            padding: 0;
            margin: 0;
            height:50%;
      #info {
         top: 2px;
         color: #444;
         height: auto;
         font-family: arial;
         font-weight: bold;
         left: 69px;
         margin: 5px;
         padding: 10px;
         position: absolute;
         width: 260px;
         z-index: 40;
         border: solid 1px #003300;
         border-radius: 4px;
         background-color: Green;
        /* Change color of icons to match bar chart and selection symbol */
            .esriPopup.darkdiv.titleButton,
            .esriPopup.darkdiv.titlePane.title,
            .esriPopup.darkdiv.actionsPane.action {
            color: #A4CE67;
        /* Additional customizations */
            .esriPopup.dark.esriPopupWrapper {
            border: none;
            .esriPopup.contentPane {
            text-align: center;
            .esriViewPopup.gallery {
            margin:0auto;
</style>
        <script src="http://js.arcgis.com/3.13/"></script>
<script>
    var map;
    require([
        "esri/map",
        "esri/dijit/Popup", "esri/dijit/PopupTemplate",
        "esri/layers/FeatureLayer",
        "esri/symbols/SimpleFillSymbol", "esri/Color",
        "dojo/dom-class", "dojo/dom-construct", "dojo/on",
        "dojox/charting/Chart", "dojox/charting/themes/Dollar", "dojo/parser",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/TitlePane",
        "dojo/domReady!"
             ], function (
        Map,
        Popup, PopupTemplate,
        FeatureLayer, SimpleFillSymbol, Color, BasemapGallery, arcgisUtils,
        domClass, domConstruct, on,
       Chart, Dollar, parser) {
          parser.parse();
          map = new Map("map", {
              basemap: "topo",
              center: [78.8718, 21.7679],
              zoom: 4
          //add the basemap gallery, in this case we'll display maps from ArcGIS.com including bing maps
          var basemapGallery = new BasemapGallery({
              showArcGISBasemaps: true,
              map: map
          }, "basemapGallery");
          basemapGallery.startup();
          basemapGallery.on("error", function (msg) {
              console.log("basemap gallery error:  ", msg);
          //The popup is the default info window so you only need to create the popup and
          //assign it to the map if you want to change default properties. Here we are
          //noting that the specified title content should display in the header bar
          //and providing our own selection symbol for polygons.
          var fill = new SimpleFillSymbol("solid", null, new Color("#A4CE67"));
          var popup = new Popup({
              fillSymbol: fill,
              titleInBody: false
          }, domConstruct.create("div"));
          //Add the dark theme which is customized further in the <style> tag at the top of this page
          domClass.add(popup.domNode, "dark");
          map.infoWindow = popup;
          //          map = new Map("map", {
          //              basemap: "gray",
          //              center: [78.8718, 21.7679],
          //              zoom: 4,
          //              infoWindow: popup
          var template = new PopupTemplate({
              title: "munugode subdivision",
              description: "{village}:  {population} are affected",
              fieldInfos: [{ //define field infos so we can specify an alias
                  fieldName: "Number_Ent",
                  label: "Entrants"
                  fieldName: "Number_Sta",
                  label: "Starters"
                  fieldName: "Number_Fin",
                  label: "Finishers"
              mediaInfos: [{ //define the bar chart
                  caption: "",
                  type: "barchart",
                  value: {
                      theme: "Dollar",
                      fields: ["Number_Ent", "Number_Sta", "Number_Fin"]
          var featureLayer = new FeatureLayer("http://3092-ggngis:6080/arcgis/rest/services/BSESWithoutOwnership/FeatureServer/0", {
              mode: FeatureLayer.MODE_ONDEMAND,
              outFields: ["*"],
              infoTemplate: template
          map.addLayer(featureLayer);
</script>
</head>
<body  class="claro">
            <div data-dojo-type="dijit/layout/BorderContainer"
            data-dojo-props="design:'headline', gutters:false"
            style="width:75%;height:75%;margin:0;">
    <div id="map"
            data-dojo-type="dijit/layout/ContentPane"
            data-dojo-props="region:'center'"
            style="padding:0;">
    <div style="position:absolute; right:20px; top:10px; z-Index:999;">
    <div data-dojo-type="dijit/TitlePane"
            data-dojo-props="title:'Switch Basemap', closable:false, open:false">
            <div data-dojo-type="dijit/layout/ContentPane"style="width:100; height:100px; overflow:auto;">
            <divid="basemapGallery"></div>
</div>
</div>
</div>
</div>
</div>
</body>
</html>
Outcomes
